A few days ago I posted about my clutch troubles. Following that, I replaced the slave cylinder which did not fix the issue. Next step is the master, then if the hydraulics are eliminated as a possibility it's on to mechanical.
My clutch master cylinder (2004 Toyota Celica GT) is sandwiched between the brake master cylinder & booster, the firewall, the inner fender, the wheel well below, the wiper cowl above, and the shock tower. The only way for me to remove it is to take out the brake master cylinder and booster for access.
Since I have ABS and don't have a tool that supports cycling the system for bleeding, has anyone done it without the tool? And if so, how? Since the master will be removed and replaced, I'm definitely going to trap some air in the ABS.
Thanks, Chris
Thanks, Chris
