1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
61 registered members (Barkleymut, alarmguy, amblerman, 86cutlass307, aquariuscsm, aray, 8 invisible), 1,234 guests, and 53 spiders.
Topics306,081
Posts5,287,017
Members71,596
Valvoline conventional #5235014 10/09/19 03:23 PM
T
tiger862 Offline OP
T
I just bought Valvoline Daily Protection 5w20 at Walmart in 5 qt
container and one in the qt size. I know both says Daily Protection but the qt is only sn and other is sn+ with only 5 qt is Synthetic Blend. I have 0w20 Advance qt so would you use conventional qt or 0w20 qt? I don't think it will make a difference
Tiger862
2018 Grand Caravan
Re: Valvoline conventional [Re: tiger862] #5235019 10/09/19 03:27 PM
P
Ponchinizo Offline
P
I would use the 0W-20 for the fill and the 5W-20 SN for top offs if needed. Just feels right.
Re: Valvoline conventional [Re: tiger862] #5235042 10/09/19 03:54 PM
W
Whimsey Offline
W
Use the Valvoline 5W-20 in the 5 qt & 1 qt containers. It doesn't matter mixing some SN with SN+, especially from the same brand and type/grade. Save the 0W-20 if you need top off oil later.
Whimsey
Re: Valvoline conventional [Re: tiger862] #5235049 10/09/19 04:03 PM
wemay Offline
Not an issue. You're good.
2019 Volkswagen Passat Wolfsburg TSI: VW OE 0W-20, OE o.filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE o.filter
Re: Valvoline conventional [Re: Whimsey] #5235088 10/09/19 04:57 PM
M
Mad_Hatter Offline
M
Whimsey
+1... you're fine mixing the synthetic with convention or just do as Whimsey stated. The only difference between the two (SN v. SN+) is the SN+ addresses LSPI.. but you're Caravan is NA, right? So it's a moot point.
Re: Valvoline conventional [Re: tiger862] #5235112 10/09/19 05:40 PM
csandste Offline
If it's SN+ it's semi syn. Label change on newer stock , same stuff
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Valvoline conventional [Re: tiger862] #5235123 10/09/19 05:59 PM
B
bullwinkle Offline
B
Some SN VWB 5W20 is also syn blend, they changed the PDS around 2 1/2 years ago.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Valvoline conventional [Re: tiger862] #5235131 10/09/19 06:10 PM
B
bbhero Offline
B
[censored]... Just this current run in my lady's 98 Camry I purposely mixed 2 qts of - Valvoline white bottle, a qt of Valvoline Maxlife red bottle, and a qt of Valvoline Advanced full synthetic LOL
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Valvoline conventional [Re: tiger862] #5235299 10/09/19 09:19 PM
T
tiger862 Offline OP
T
Thanks everyone I wasn't sure the SN conventional was synthetic blend as it wasn't SN+
I know the + is for LSPI and that doesn't apply to my Caravan but I wanted a blend. I can't see synthetic for 6 month oil changes
Tiger862
2018 Grand Caravan
Re: Valvoline conventional [Re: bbhero] #5235300 10/09/19 09:20 PM
T
tiger862 Offline OP
T
Now you have your blend
LOL
Tiger862
2018 Grand Caravan
