My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
40 registered members (carlprop, c502cid, Aaron_Patton, blufeb95, 5 invisible), 1,084 guests, and 56 spiders.
Topics306,227
Posts5,288,596
Members71,608
Will remote oil filter systems cause dry startups? #5234846 10/09/19 11:59 AM
M
motor_oil_madman Online Content OP
OP Online Content
M
This is probably the best place to ask, so here it goes. I bought a new 350 Chevy for my boat. It's a complete drop in engine. Well once you put it in the boat it's pretty hard to loosen the oil filter especially if it got overtightened, so it looks like it's pretty common for a marine engine to have the oil filter relocated. My concerne is it loosing prime. Also in the picture it looks like the filter is upside down, so it looks like a mess to change.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Will remote oil filter systems cause dry startups? [Re: motor_oil_madman] #5234854 10/09/19 12:04 PM
R
Reddy45 Offline
R
Wouldn't the relocation lines hold oil once the engine is shut off anyway? Seems no different.
Re: Will remote oil filter systems cause dry startups? [Re: motor_oil_madman] #5234861 10/09/19 12:16 PM
T
tundraotto Offline
T
If the oil filter has and Anti-Drain-Back-Valve - it should not matter - of course, depending on how well the valve works.
Re: Will remote oil filter systems cause dry startups? [Re: motor_oil_madman] #5234887 10/09/19 12:46 PM
CT8 Offline
What do you mean by dry start. I hear the term often. When the engine is not running the oil drains from the passage ways.
2015 F150 2.7
2018 F350 6.2
Re: Will remote oil filter systems cause dry startups? [Re: CT8] #5234925 10/09/19 01:32 PM
bdcardinal Offline
Basically the amount of time it takes for the engine to build oil pressure and oil to get up to the head(s). That is one of the cool things about a dry sump system, you can take the belt off and run the pump with a drill to build pressure before starting the engine.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Will remote oil filter systems cause dry startups? [Re: motor_oil_madman] #5234968 10/09/19 02:24 PM
Donald Offline
Most remote or bypass filter setups I have seen have the threaded base pointing up. So nothing will drain with ADBV or not.
2015 Ford F-250 w/Powerstroke
Re: Will remote oil filter systems cause dry startups? [Re: motor_oil_madman] #5235070 10/09/19 04:27 PM
SirTanon Offline
IF there is something in the remote setup, or within the engine's internals that is causing drain-back of the oil after the engine is shutoff, then it's possible that the remote system might lead to a couple seconds of 'dry' start-up. If it's installed right, there are no leaks, and the engine is working properly, then no, I wouldn't think so.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Will remote oil filter systems cause dry startups? [Re: tundraotto] #5235146 10/09/19 06:19 PM
M
OP Online Content
M
Yeah a lot of them dont work well. I guess if you use a good quality filter it's a non issue.
Re: Will remote oil filter systems cause dry startups? [Re: tundraotto] #5235306 10/09/19 09:36 PM
Dyusik Offline
I have no ADBV in my filter and the remote filter set up is filled with oil.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 21K RT6 15w40, XG7317
18 RAM 3500 15k Delvac 15w40, DBL7349
96 Cherokee
Re: Will remote oil filter systems cause dry startups? [Re: motor_oil_madman] #5243239 10/18/19 11:29 AM
L
Linctex Offline
L
You'll need to prime the system if the engine has never been run before - - ever.
Generally, You aren't starting "under load".
If your boat is like mine, you start it at IDLE and in NEUTRAL...
That's really a very "low-stress condition for the engine to run in.
Use a timer and check your oil pressure gauge on a cold start.
If it takes more than 5 seconds of running time to build pressure, I would be surprised.
Re: Will remote oil filter systems cause dry startups? [Re: motor_oil_madman] #5292077 12/12/19 06:13 AM
L
ledslinger Offline
L
If you can change the filter in the stock location, skip the remote setup.
