1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
68 registered members (AJB0009, 14Accent, aba4430, Alfred_B, 69Torino, 1978elcamino, 8 invisible), 1,646 guests, and 79 spiders.
Topics306,083
Posts5,287,066
Members71,596
Lubegard Platinum Dosage #5234770 10/09/19 10:33 AM
charmer37 Offline OP
I have a question about how much Lubegard Platinum i need to use, The instructions says use 1 ounce per quart of atf for the total capacity of the transmission. I have a 9 quart capacity system so do i use 9 ounces of lubgard platinum? I'm doing a drain and fill and that only use 5 quarts of transmission fluid so figured i need to use only 5 ounces of Platinum, Just trying to figure out the proper dose of Lubegard Platinum...Thanks.
Re: Lubegard Platinum Dosage [Re: charmer37] #5234778 10/09/19 10:41 AM
G
Gannet167 Offline
G
Regardless of what you drain and add, if you need an ounce per quart and the transmission has 9 quarts........
Just dump the whole 10 oz bottle in. It won't hurt anything to have an extra ounce.
Re: Lubegard Platinum Dosage [Re: Gannet167] #5234780 10/09/19 10:43 AM
Ok cool, I thought about it but thought i would ask to make sure i'm not adding to much....Thanks
Re: Lubegard Platinum Dosage [Re: charmer37] #5234791 10/09/19 10:51 AM
SubieRubyRoo Offline
I wouldn't use Platinum, just use Red. MolaKule had some strong opinions against the makeup of the Platinum, and said Red was a better choice. I believe he said Platinum has a very heavy dose of friction modifiers, and that you couldn't really be sure what havoc it may wreak in your tranny until it was too late; Red is not friction-modified. I haven't had any issues with Red. Use 1 oz per total capacity.
De omnibus dubitandum.
Re: Lubegard Platinum Dosage [Re: SubieRubyRoo] #5234798 10/09/19 10:55 AM
I used Lubegard Red in the past, Its good stuff.
Re: Lubegard Platinum Dosage [Re: charmer37] #5234816 10/09/19 11:28 AM
MolaKule Offline
Global Moderator
Global Moderator
1) What problem are you trying to solve?
2) LubeGard Platinum has friction modifiers that could cause wet-clutch clutch slippage;
3) If you have evidence of or suspect varnishing, LubeGard Red would be the proper additive.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Lubegard Platinum Dosage [Re: charmer37] #5234841 10/09/19 11:57 AM
L
Lowflyer Offline
L
For best results: 0.
Re: Lubegard Platinum Dosage [Re: charmer37] #5234855 10/09/19 12:06 PM
demarpaint Offline
I'd use the red.
God Bless Our Troops
Re: Lubegard Platinum Dosage [Re: charmer37] #5234885 10/09/19 12:44 PM
J
Jetsfan421 Offline
J
I use the red on every transmission that I have, problems or not. The Platinum is supposed to be a conversion fluid that turns regular atf into highly friction modified fluid. If you suspect heavy varnishing you can overdose the red at 2oz per quart of fluid.
Re: Lubegard Platinum Dosage [Re: charmer37] #5235475 10/10/19 02:57 AM
M
metroplex Offline
M
Would Luibegard Red help protect newer transmissions that use Mercon LV / Dexron VI? I know Lubegard claims Red is compatible. I just wanted to know if it was worthwhile to add. One application has 87k miles and I wanted some extra protection. The other 2 applications have under 20k miles.
Re: Lubegard Platinum Dosage [Re: charmer37] #5235540 10/10/19 06:24 AM
Lubegard Red AFAIK is the only transmission additive to have ever been "certified"/recommended by OEMs, so you can use it with confidence. They talk about it on the product webpage.
Re: Lubegard Platinum Dosage [Re: metroplex] #5235561 10/10/19 06:38 AM
demarpaint Offline
IMO it is worthwhile to add, has a huge following, and is used by a lot of transmission shops. Opinions vary on using any kind of an additive though. So do your homework and base your decision on that.
Re: Lubegard Platinum Dosage [Re: SubieRubyRoo] #5235563 10/10/19 06:39 AM
B
BMWTurboDzl Offline
B
I decided to tool around their site and I saw their proof of their "OEM". It was a circa 1993 SAAB TSB ! lol LOL
435i
Re: Lubegard Platinum Dosage [Re: charmer37] #5235764 10/10/19 10:47 AM
Originally Posted by CARS magazine from 2009
When ILI developed its patented LXE® (Liquid Wax Ester) Technology and began packaging it in its currently world renowned LUBEGARD branded products it took the transmission rebuild industry by storm due to its ability to dramatically reduce comebacks. LUBEGARD particularly its ATF Protectant became the #1 used product by the transmission industry and automobile original equipment manufacturers (OEM’s) took notice. Now over 20 years have passed and LUBEGARD ATF Protectant itself is now Used, Endorsed, Designated and Approved by eight OEM’s!
Based in Seattle, Washington, ILI is a leading manufacturer of unique chemistries and related products for the automotive, industrial, and various other chemical markets. Currently holding more than 100 U.S. and foreign patents.
I agree they could be more open about which OEMs have approved it, but it's much greater than just SAAB from 1993.
