How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
86 registered members (ABN_CBT_ENGR, ARCOgraphite, anthonym6, aquariuscsm, amh, AndyB, 8 invisible), 1,917 guests, and 32 spiders.
Topics306,111
Posts5,286,761
Members71,588
MB 229.5 VS 229.6 #5234764 10/09/19 10:28 AM
J
JohnG Offline OP
J
I've read many posts on this site about the old tried and true MB 229.5 requirement, some say it is a difficult standard to meet, others say not so much. I recently purchased a 2018 E300 with the gas turbo 4 cyl. It runs extremely well for a 4 cyl. and you'd swear it was a V6. It reminds me of driving my long gone Merkur with the 2.3L turbo4!
My question is the owners manual gives 2 specs for the engine oil: 229.5 OR 229.6. No mention of oil weight, ambient outdoor operating temperatures, nothing. When the Service Assist screen is brought up it even asks which spec oil was installed.
Does anyone have information on the two standards and what differences there are between the two? Mercedes is not very forthcoming with info such as this.
I live in central Florida so the temps are usually pretty hot, but I will make an occasional trip to Pittsburgh PA, usually in winter.
Re: MB 229.5 VS 229.6 [Re: JohnG] #5234799 10/09/19 10:57 AM
K
kschachn Online Content
Online Content
K
This thread discusses the differences:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4783024/New_Mercedes_Benz_Spec._229.6
And with an approval like the ones from Mercedes-Benz no grade designation is really required. The approval gives a minimum HTHS which for the most part dictates the grade, you can fight over the winter rating a bit but that is determined by your operating environment. There in Daytona Beach the grade of one approved oil over another is irrelevant. In your case I would purchase the least expensive oil at Walmart that carries either approval, and it is probably Mobil 1 0W-40 (especially with rebate) or Castrol 0W-40. Both are excellent oils and inexpensive.
Here is the good old Lubrizol Relative Performance Tool chart that shows the difference is a slightly lower HTHS:
[Linked Image]
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: MB 229.5 VS 229.6 [Re: JohnG] #5234806 10/09/19 11:07 AM
d00df00d Offline
Your manual doesn't say anything about viscosity or ambient temps because MB figures any oil that meets 229.5 or 229.6 should be fine in any ambient temp you're likely to see.
AFAIK, all 229.5 oils are 0W-30, 5W-30, 0W-40, and 5W-40, and they're all fully synthetic (or they wouldn't be able to pass the testing), so it's not like there's a massive range. I'd imagine 229.6 would be similar.
Not sure exactly how 229.6 compares to 229.5. Hopefully someone else can chime in on that.
2008 BMW M3 Sedan 6MT
Re: MB 229.5 VS 229.6 [Re: d00df00d] #5234833 10/09/19 11:51 AM
edyvw Offline
More focus on mpg, other than that, same requirements when it comes to wear, deposits, oxidation etc.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: MB 229.5 VS 229.6 [Re: JohnG] #5234848 10/09/19 12:00 PM
Z
zeng Offline
Z
229.6 is based on A5B5, Hths => 2.9 mPa*s and for FE, comes in only 0W30 or 5W30.
229.5 is based on A3B4, Hths => 3.5 mPa*s , comes in xW30 or xW40 .
Re: MB 229.5 VS 229.6 [Re: JohnG] #5234850 10/09/19 12:01 PM
F
Fotoflame Offline
F
Just for clarification sake, MB 229.6 approved oil only comes in 0W-30 and 5W-30.
Attached is a link to the approved 229.6 oils. Less to choose from than 229.5, but I imagine the list will get longer over time.
MB 229.6 Approved Oils
Re: MB 229.5 VS 229.6 [Re: JohnG] #5234852 10/09/19 12:02 PM
edyvw Offline
Use MB229.5. As for ambient temperature, any MB229.5 can work in Alaska or Saudi Arabia.
Re: MB 229.5 VS 229.6 [Re: edyvw] #5234888 10/09/19 12:48 PM
K
Online Content
K
I agree. The small fuel economy improvement with 229.6 is offset by the higher cost of available oils. Good luck finding something as inexpensive as Castrol 0W-40 at Walmart on rollback. Plus you get a higher HTHS.
1994 BMW 530i, 252K
Re: MB 229.5 VS 229.6 [Re: JohnG] #5234962 10/09/19 02:19 PM
P
paoester Offline
P
Its a difficult standard to meet.
Notice only full synthetics have ever been able to qualify for it. Indy cars have used it in the past.
When the Service Assist screen is brought up it even asks which spec oil was installed..
Very cool of Mercedes to do that. Wonder why. Is it to make a statement to the oil changer that they need to look for their special spec (229.5 or 229.6) instead of just putting in plain vanilla SN oil? Or, does the engine computer use the information to monitor viscosity levels like Chrysler Hemis do with P1521 "incorrect engine oil type" viscosity warnings, infered from rpm, temperature, pressure readings (?).
Its hard to find 229.6 oil. Bevo official list for it is short. https://bevo.mercedes-benz.com/bevolisten/229.6_en.html
Might as well use the thicker walmart 0w40 oils. Cheap and decent.
Re: MB 229.5 VS 229.6 [Re: JohnG] #5234989 10/09/19 02:51 PM
P
Pelican Offline
P
If you are going to keep the Benz for a long time use 229.5 and also follow the owner's manual to the letter, MB doesn't forgive slakers wink I'm an ex MB owner.
Re: MB 229.5 VS 229.6 [Re: paoester] #5235010 10/09/19 03:18 PM
B
barryh Offline
B
Quote
When the Service Assist screen is brought up it even asks which spec oil was installed..Very cool of Mercedes to do that. Wonder why. Is it to make a statement to the oil changer that they need to look for their special spec (229.5 or 229.6) instead of just putting in plain vanilla SN oil? Or, does the engine computer use the information to monitor viscosity levels like Chrysler Hemis do with P1521 "incorrect engine oil type" viscosity warnings, infered from rpm, temperature, pressure readings (?).
On my older car there is a choice of 229.3 vs 229.5 and you have to enter the choice when resetting the service indicator. Presumably it affects the maximum miles to the next service. I don't think it's any more sophisticated than that.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: MB 229.5 VS 229.6 [Re: edyvw] #5235029 10/09/19 03:39 PM
L
loneryder Offline
L
+1
Re: MB 229.5 VS 229.6 [Re: barryh] #5235059 10/09/19 04:12 PM
P
paoester Offline
P
I don't see how either 229.5 or .6 would last longer than the other. Lubrizol says they are about as strict. Visc is different is about all. Interesting Mercedes does this. If GM did that, they could have people do 5k miles on SN+, and 8k miles on dexos1, for example. Of course then SP-GF6 comes along and it might about equal dexos1 anyway. Specs are a mess around the world.
Mercedes and other German engine makers take this oil stuff seriously. My '19 Tiguan tells me if the oil level is too low, and it specs very high quality VW 508 0w-20 oil, which they require to have a green dye to make sure car owners have it. ("Achtung! You veel use the right oil!" ) During break-in, I put in some Pennzoil full syn from an old stash, taking the chance I'll get away with it til the next "real 508" oil change. If something happens maybe they will take the Schultz view of my indiscretion:
[Linked Image from i1.wp.com]
Funny old show. I still watch it once in a while on cable. Good comedy writing.
Re: MB 229.5 VS 229.6 [Re: JohnG] #5235106 10/09/19 05:29 PM
J
JohnG Offline OP
J
Thanks Guys!
I think the list has gotten longer since that quoted thread, but not by much.
I did get the Ravenol FDS 5w-30 for my next couple of (ANNUAL) oil changes from Blauparts. It's interesting to see that 0W-40 is ok from Alaska to Saudi Arabia, I wonder if the same can be said for a PAO Vollesynthe Oil in 5W30 . I imagine it will work just fine with MAYBE a little boost to fuel economy. We'll see over the next couple of years I suppose. My oil changes in central Florida are mostly determined by the season anyway. Nobody is going to change oil in a 98 degree garage in the middle of summer, so mine are always done in January or February.
I am a little disappointed that nobody commented on the 1986 Merkur. I can only imagine what that little car would have done with today's engine oils and a Mercedes 9 speed transmission!
Some cars you just never forget.
Re: MB 229.5 VS 229.6 [Re: JohnG] #5235132 10/09/19 06:11 PM
P
paoester Offline
P
I did get the Ravenol FDS 5w-30 for my next couple of (ANNUAL) oil changes from Blauparts. It's interesting to see that 0W-40 is ok from Alaska to Saudi Arabia, I wonder if the same can be said for a PAO Vollesynthe Oil in 5W30 . I imagine it will work just fine with MAYBE a little boost to fuel economy. .
Ravenol is all PAO, and that one has tungsten, very nice. With all that FM and a lower HTHS, this means your engine uses less energy. Estimated about 2% better fuel economy compared to a 40 weight at HTHS 3.6, and your FDS with 3.0 has what may be more moly and tungsten overall to augment basic HTHS physics. You might not ever notice the ~2% difference or care. Toyota insists on thin oil with a lot of FM to raise fuel economy, for example, using 0w16 in some cases. That works.
I am a little disappointed that nobody commented on the 1986 Merkur. I can only imagine what that little car would have done with today's engine oils and a Mercedes 9 speed transmission.
In '85, I saw the radical new Taurus, and Ford was seen as a real trendsetter for both that and the Bob Lutz Merkur import. The Merkur's price was high, and Ford never won over the German car crowd who mostly wanted a real BMW or Mercedes rather than an expensive euro-Ford. Good car though. Just image issues.
