I'm wanting to connect my reel to my compressor that's about 50' away. The compressor's ball valve as well as the reel's inlet are 1/2" fittings. The reels's hose is 1/2" with a 3/8" fitting on the end.
Will a 1/2" hose with 1/2" fittings be sufficient or will I need a 3/4" hose with 1/2" fittings? The latter seems like an overkill, but I don't want anything choked down either.
Thanks.
Thanks.
