Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Jcvjr, Haywood, ToOliwer, AbbeyRoad, RPF
71587 Registered Users
62 registered members (Bigpetee, aquariuscsm, Astro_Guy, Best F100, Alain2, 7 invisible), 1,515 guests, and 41 spiders.
Topics306,110
Posts5,286,695
Members71,587
Changing Oil Brands Oddity ? #5234540 10/09/19 07:07 AM
ChrisD46 Offline OP
In my last oil change I ran Valvoline Advanced 5W30 (no issues) before changing oil out to QSUD 5W20 ... Surprisingly , for the first couple of days the engine ran slightly rough and the gas mileage actually dropped before smoothing out and the gas mileage improved . Is there any truth to the belief that this happened as a result of the new oil needing a little time to remove the old add pack on metal surfaces before laying down it's own new add pack on metal surfaces and smoothing out ?
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234550 10/09/19 07:16 AM
Char Baby Offline
I've moved back & forth between the two grades just as you did. In fact, I've use the same oil brands & weights just as you did, going from one to the other in the same order you did. However if anything, I noticed a smoother/quieter engine with the QSUD.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234555 10/09/19 07:20 AM
A
alarmguy Offline
A
No truth, your engine roughness had nothing to do with the oil change/brands.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234561 10/09/19 07:27 AM
B
buster Offline
B
It's more likely that the gas you used had changed in some way. However, what you experienced has been noted before and could have something to do with the change in additive systems, although unlikely.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Changing Oil Brands Oddity ? [Re: alarmguy] #5234620 10/09/19 08:24 AM
A
ARCOgraphite Offline
A
Incorrect. Flat Earther ! smile
The add pack changeover effect has been discussed for decades.
I though my VW was going to blow up it ran so bad after an OC.
Going from a Ti DP oil to a different package had a similar
"engine is about to blow" effect.
It's that bad sometimes.
ChrisD46 you should have stuck with the Valvoline advanced. Best stuff out there right now in 5W30
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234653 10/09/19 08:48 AM
O
oldhp Offline
O
I highly doubt changing oil brands or weights had anything to do with engine running rough. If that was the case "almost every" car would go through this rough running engine phase.
I think gasoline or possibly MAP/MAF sensor got a piece of dirt on it.
On the very, very, very outside.........0001%, maybe, maybe going to "thinner" oil did not let 1 or more hydraulic lifter pump up for some reason.
Either that or car was mad mad about getting QSUD 5W20 and wanted it's Valvoline blood back, because Halloween is coming.................. shocked2
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234656 10/09/19 08:51 AM
JohnnyJohnson Offline
I change weights and oil almost every OCI and its never been an issue in the 15 years + I've owned the Corolla.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Changing Oil Brands Oddity ? [Re: JohnnyJohnson] #5234688 10/09/19 09:20 AM
wemay Offline
Me too, never noticed any difference after the initial psychological effect of feeling smoother just 'cause new oil is in there.
2019 Volkswagen Passat Wolfsburg TSI: M1 EP 0W-20, Fram 11784
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, H/K oil filter
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234693 10/09/19 09:21 AM
A
A
I stand by my observations over 70 cars and 100's of oil changes.
I'm just a sensitive guy smile
Re: Changing Oil Brands Oddity ? [Re: ARCOgraphite] #5234704 10/09/19 09:34 AM
wemay Offline
You may be right, i just never noticed...smile
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234705 10/09/19 09:35 AM
F
Fawteen Offline
F
I've never seen any sort of change in the engine when changing oils.
I once had a headlight go out right after changing the oil though.
Re: Changing Oil Brands Oddity ? [Re: ARCOgraphite] #5234709 10/09/19 09:39 AM
B
buster Offline
B
I believe you. With that many oil changes on many cars and being in tune with the engine, you're likely bound to hear some differences. There was once a member on here that used to work for XOM and he described it as "seating". Now, I'm sure this only happens in a smaller percentage of cases, but I can see it being totally legit. Especially if you're maybe changing from one oil with a very unique and different chemistry to another.
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234767 10/09/19 10:31 AM
M
mclasser Offline
M
I've noticed some oils make the engine quieter, but never experienced rough running from switching brands.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234796 10/09/19 10:54 AM
A
aquariuscsm Online Content
Online Content
A
Maybe it’s because you went with a thinner oil? I’d go back to a W30.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Changing Oil Brands Oddity ? [Re: ChrisD46] #5234884 10/09/19 12:44 PM
M
Mad_Hatter Offline
M
I change oil mfg all the time and sometimes even grade, albeit less often than I do change mfgs... and I've never noticed an appreciable difference in mpg's. What I do notice when it comes to mpg's is my occasional lead foot!πŸ˜‚
However, some lube brands do seem to produce more "noise" in my valve train for the first few hundred miles but it almost always settles down...I say "seems" because I have no real scientific way to substantiate that other than my calibrated ear and having sat behind the steering wheel for all 164k+ miles on my vehicle.πŸ˜‚
