any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
Atf for my E4od
by R1jake - 05/25/20 04:04 PM
Having trouble finding the right part (VW)...
by gregk24 - 05/25/20 04:03 PM
Need a sensible but fun daily
by dparm - 05/25/20 03:52 PM
FJ cruiser knock sensors
by Chris142 - 05/25/20 03:51 PM
Rock Auto now carries Maval steering racks and pumps
by slacktide_bitog - 05/25/20 03:10 PM
Review: Cardone Reman Power Steering Pump
by RevelationLion - 05/25/20 02:09 PM
Carvana
by Bogdon - 05/25/20 02:06 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
95 registered members (aquariuscsm, apollo18, 2015_PSD, 55hambone, 28oz, 53' Stude, 7 invisible), 2,515 guests, and 38 spiders.
Topics305,870
Posts5,281,780
Members71,528
G11 and G48 interchangeable? #5234536 10/09/19 07:01 AM
F
FordCapriDriver Offline OP
F
One thing that has me wondering lately, i am looking at possibly buying a 1991 Ford Escort RS 2000 ( European 150hp version )
Looking at fluid recommendations for it i noticed :
The recommended coolant is Ford ESD-M97B4-A
A quick search shows most of the coolants meeting this spec are Blue and claim to meet either VW G11 or G48, or both at the same time.
However, G11 is supposed to be a plain IAT containing Silicate, Borate, Benzoate and some form of Azole.
G48 on the other hand is a Silicate HOAT with no borate ( or benzoate? )
I am confused about how these coolants can be considered interchangeable or meet both specs at the same time?
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5234672 10/09/19 09:10 AM
CT8 Offline
I don't know the specs but decide on one then do a complete flush if worried about the compatibility .
2015 F150 2.7
2018 F350 6.2
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5234874 10/09/19 12:32 PM
N
nthach Offline
N
Sodium benzoate is an organic acid, and also found in G-05. G-05 uses borate as well to protect cylinder liners, while azole is there to protect copper.
G-11 is VW's old school coolant before G-12(G-30) was used. G-48 is 2-EHA.
In theory, all OATs should play nice with each other but not always.
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5234876 10/09/19 12:34 PM
N
nthach Offline
N
Also, G-05 has nitrite as well which is why Ford and Daimler was fond of it for diesel applications.
Re: G11 and G48 interchangeable? [Re: nthach] #5235638 10/10/19 08:32 AM
F
F
Borate used to protect cylinder liners? you sure about that?
The only use of Borate in a coolant that i know of is that it acts as a pH buffer, it doesn't have any corrosion inhibitor properties that i know of, in fact it's well known to be aggressive towards aluminium.
Also about 2-Eha being present in G48, i do know of one particular G48 coolant made by a brand called AD that doesn't have any mention of 2-Eha , at least in the SDS, other brands like Glysantin do seem to mention it in the SDS.
So what i understand is that G11 uses Sodium Benzoate as the OAT inhibitor and G48 uses 2-Eha and / or something else depending on brand?
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5235876 10/10/19 12:38 PM
N
nthach Offline
N
You might be right about borate being a pH buffer - and the reason why the Japanese frown upon borate for pitting. I thought it was a component used in HD coolants to help protect wet-sleeve cylinder liners like what's found on bigger diesels.
The labels on BMW coolant in the US state 2-EHA. As long as the coolant itself or the add pack is coming from BASF it will have 2-EHA. In the US, BASF doesn't sell the Glysantin brand, Valvoline sells all the G-xx stuff under the Zerex label.
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5236716 10/11/19 08:44 AM
F
F
If 2-Eha is present in a coolant is MUST be in the SDS ( Safety Data Sheet ) of the coolant correct?
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5237086 10/11/19 02:44 PM
N
nthach Offline
N
A formulator/distributor can leave any non-hazardous or trade secret ingredients out of the SDS. 2-EHA is a hazardous chemical but in the concentrations used it can be left out of an SDS or listed as a trade secret, with the option of listing it as a NJRTK disclaimer.
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5269830 11/17/19 11:43 AM
Schuttwegraeumer Offline
G11 is the VW Product with TL 774 C
G48 is the Glysantin Product with TL 774 C
I dont know if VW used Glysantin these days but this 2 product could be the same.
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5269919 11/17/19 01:25 PM
W
Warstud Offline
W
Isn't it M97B44-A
Re: G11 and G48 interchangeable? [Re: Schuttwegraeumer] #5270188 11/17/19 07:14 PM
A
AC1DD Offline
A
They do and always have at least in the European produced vehicles use BASF Glysantin.
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5412477 04/25/20 03:53 AM
2
2EHA Offline
2
Does anyone actually make this mythical high silicate no-benzoate no-2eha IAT G11?
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5412756 04/25/20 11:33 AM
F
F
Well right now i am running Repsol brand G11 in both my cars, Repsol customer service was really helpful and confirmed it has Silicate, Benzoate, Borate and Tolytriazole and no 2-Eha.
Re: G11 and G48 interchangeable? [Re: FordCapriDriver] #5412761 04/25/20 11:38 AM
2
2EHA Offline
2
So for all intents and purposes this blend of G11 is nitrate free-G05. Probably the closest stuff to the original G11.
Re: G11 and G48 interchangeable? [Re: 2EHA] #5413588 04/26/20 11:37 AM
F
F
Yes G-05 is pretty close but has about Half the Silicate, about 200-300ppm depending on the brand, G11 has 500-600ppm.
I'm not sure what you mean by the closest stuff to the original G11, on the TDS it clearly states that it meets the VW TL-774-C spec which is the original G11, Silicate, Benzoate, Borate and an Azole, and it's Blue which is the colour G11 has always been.
G11 never has had Nitrite ( you said Nitrate but i assume that was a typo , as G-05 has Nitrite not Nitrate ).
