1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
83 registered members (Alfred_B, 69Torino, 1978elcamino, 77GrandPrix, 53' Stude, amblerman, 5 invisible), 1,583 guests, and 38 spiders.
Topics306,083
Posts5,287,059
Members71,596
Door still rust advice... #5234523 10/09/19 06:52 AM
O
Oey12 Offline OP
O
This is my 2017 4Runner on the driver’s door sill with a small rust bubble on the corner. I am looking for advice on how to prep, seal, and paint it so it doesn’t cause any further issues. I just want it done properly being that the truck is only two years old and I live in a heavy salt state (NY). I am planning to remove that plastic trim this weekend to see what else is going on under there. Any advice is greatly appreciated...
[Linked Image]
[Linked Image]
Re: Door still rust advice... [Re: Oey12] #5234539 10/09/19 07:04 AM
M
MasterSolenoid Offline
M
Good catch.
Most people (not BITOG people) would let it get worse.
Once the plastic is removed, I would:
1) Take some type of scrapper and scrape off all the rust / no rust neutralizer needed.
2) Use small paint brush with self-etching Primer
3) Paint with same color Touch-Up Paint.
Now, what you do with any undercarriage rust is a topic in itself.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Door still rust advice... [Re: Oey12] #5234544 10/09/19 07:12 AM
stevejones Offline
Post a pic after removing the trim.
Re: Door still rust advice... [Re: stevejones] #5234551 10/09/19 07:17 AM
supton Online Content
Online Content
Ditto. I think that is damage from water coming in from your shoe, and not from road salt spray.
What are you doing to mitigate rust underneath the vehicle? On the undercarriage that is.
Also, are you going to be 5 and done? If so, I'd think about just sanding down, applying touchup paint, calling it a day--if you're going to trade out of in a few years.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Door still rust advice... [Re: Oey12] #5234553 10/09/19 07:19 AM
Char Baby Offline
Clean it up, apply some EXTEND and dab some paint on it. It'll last forever.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Door still rust advice... [Re: Oey12] #5234634 10/09/19 08:31 AM
O
Oey12 Offline OP
O
Thank you all for the quick responses! I am meticulous about my vehicles and I plan on keeping this anywhere from 5 to 7 MORE years. In all honestly the truck is a perfect old school body on frame SUV. It hauls my family and tows my ATVs great. And I can have a lot of fun offroad...on moderate paths. To me the simplicity of the truck is priceless... Anyway doing it the correct way is paramount to me and in all honestly I really never tinkered with auto body stuff. And after further inspection I do agree that its probably from salt that was on my shoes.
Re: Door still rust advice... [Re: Oey12] #5234637 10/09/19 08:35 AM
O
Oey12 Offline OP
O
Here are more pictures...after seeing the underneath I am slightly concerned... [Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Re: Door still rust advice... [Re: Oey12] #5234654 10/09/19 08:50 AM
SubieRubyRoo Offline
It's obviously from movement of the plastic piece, gently sand the area, prep & paint it, then I would put a thin piece of felt or 3M poly tape on the bottom of the piece to be a sacrificial layer between the trim and body. It's either moving when your foot hits the plastic piece, or when the door closes and jiggles the trim back and forth.
De omnibus dubitandum.
Re: Door still rust advice... [Re: SubieRubyRoo] #5234661 10/09/19 08:55 AM
PimTac Offline
This sounds like good advice. I might pop the passenger side and check it out and do the same.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Door still rust advice... [Re: Oey12] #5234674 10/09/19 09:11 AM
doitmyself Offline
That lower one looks like a metal defect - the cratering - that probably came from the factory. Maybe a weld burn? There really seems to be a lack of corrosion protection under that paint. Most car bodies are dipped in some kind of metal rust protection bath before painting.
If still under warranty, I would have a dealer look at it and get them to repair it. The problem will then be documented if it recurs. It also seems that you will have to figure out how to get that plastic to not rub through the paint. Maybe clear film?
Re: Door still rust advice... [Re: Oey12] #5234685 10/09/19 09:19 AM
K
KGMtech Offline
K
I would send photos to both the dealer and the local Toyota field service person. This is something that can't just be affecting your car and only your car! fast forward 4 years and for some reason you have a perforation hole, you have evidence that you notified them when it was just surface rust.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Door still rust advice... [Re: Oey12] #5234725 10/09/19 09:54 AM
stockrex Online Content
Online Content
I have some serious rust under my ridgeline sills (10 years of michigan salt and sand)
I plan to wire bush them with a drill
treat the rust with 2 coats of rust oleum rust primer
then 2 coats of rust oleum auto paint,
I plan to take q tip and apply marine grease to the inside of the little holes where the sill plastic snaps on to after painting.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Door still rust advice... [Re: Oey12] #5234891 10/09/19 12:49 PM
G
Gasbuggy Offline
G
Use your corrosion warranty, let the dealership fix it.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Door still rust advice... [Re: Oey12] #5234909 10/09/19 01:03 PM
M
Mad_Hatter Offline
M
Why aren't you taking it back to the dealership? Wouldn't this be a warranty issue? The nickel or zinc coating shouldn't be diminished that quickly, could it?
I'd get it on record in the event more, severe signs of premature corrosion appear.
Re: Door still rust advice... [Re: Oey12] #5234964 10/09/19 02:21 PM
dishdude Offline
Did you buy this new? There's an awful lot of orange peel (and is that a run in the paint?) in the first picture of the post that has the sill plate removed that makes me think it has been repainted.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
