Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
22 registered members (Chesterr, Cdn17Sport6MT, daves87rs, blufeb95, BoiseRob, ctechbob, 2 invisible), 808 guests, and 65 spiders.
Topics306,228
Posts5,288,621
Members71,608
Check Engine light vs fault #5234516 10/09/19 06:38 AM
M
madRiver Offline OP
M
I have a 2018 Tiguan and the only very occasional issue is backing up with a cold/cool engine it hesitates and near stalls and then catches back. It has never illuminated a check engine light.
Does the computer store codes but not illuminate the check engine light?
There is a specific TSB for this and would like to get addressed:
[Linked Image from uploads.tapatalk-cdn.com]
Re: Check Engine light vs fault [Re: madRiver] #5234568 10/09/19 07:32 AM
A
atikovi Offline
A
Sure does. Could have pending codes stored that won't illuminate the CEL, yet. Could have transmission codes stored some of which won't illuminate the CEL.
Re: Check Engine light vs fault [Re: madRiver] #5234594 10/09/19 08:02 AM
M
mk378 Offline
M
If the ECU loses memory backup power it may run badly the next time the engine is started until it can recalibrate. The only other symptom of that would be the emission ready codes become not ready for a time. To troubleshoot a highly intermittent problem you really should have your own code scanner.
Re: Check Engine light vs fault [Re: mk378] #5234811 10/09/19 11:21 AM
M
madRiver Offline OP
M
I understand for self diagnosis however this vehicle is covered by a 6yr/72k mile warranty. My hope is faults not CEL are in fact stored. I am unclear if a dealer will perform a TSB unless there is actual fault they can reproduce or diagnose.
Re: Check Engine light vs fault [Re: madRiver] #5234901 10/09/19 12:57 PM
M
Mad_Hatter Offline
M
They won't. A TSB isn't an actionable item until there's a bona fide fault.
If you don't have an OBD2 go to AZ and see if they can pull up any pending faults.
It would be nice to know if your O2's are still in closed loop when this happens. In closed loop you're running rich, maybe the rich air/fuel is causing a stall?? With an OBD2 you could monitor such things in real time.
Just a hunch...idle control maybe? At cold startup you're idling high then you put it into gear and the rpms drop too low, momentarily, causing it to almost stall out??.. check out the rpms change from P to D when cold...is it dipping well below 600 rpms for a moment?
