1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
72 registered members (aba4430, Alfred_B, AndyB, 69Torino, 1978elcamino, 77GrandPrix, 6 invisible), 1,604 guests, and 64 spiders.
Topics306,083
Posts5,287,066
Members71,596
Air hose fitting confusion #5234471 10/09/19 05:08 AM
dlundblad Offline OP
I’m wanting to connect my reel to my compressor that’s about 50’ away. The compressor’s ball valve as well as the reel’s inlet are 1/2” fittings. The reels’s hose is 1/2” with a 3/8” fitting on the end.
Will a 1/2” hose with 1/2” fittings be sufficient or will I need a 3/4” hose with 1/2” fittings? The latter seems like an overkill, but I don’t want anything choked down either.
Thanks.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Air hose fitting confusion [Re: dlundblad] #5234481 10/09/19 05:48 AM
B
billt460 Offline
B
Originally Posted by dlundblad
I’m wanting to connect my reel to my compressor that’s about 50’ away. The compressor’s ball valve as well as the reel’s inlet are 1/2” fittings. The reels’s hose is 1/2” with a 3/8” fitting on the end. Will a 1/2” hose with 1/2” fittings be sufficient or will I need a 3/4” hose with 1/2” fittings? The latter seems like an overkill, but I don’t want anything choked down either.
Thanks.
1/2" will be fine. The problem with large, high capacity hoses, (both air and water), is they are very heavy and bulky. Most of the time too much so to justify their increased capacity. They become more of a nuisance than a benefit. Unless you are running large, high volume air tools, or mounting and filling large tires, they're just not necessary.
Besides, you already have a 1/2" ball valve coming out of the compressor, so it's already restricted to 1/2" coming out of the tank. You won't gain any more airflow by going larger in between, unless you replace the ball valve to the same size.
Re: Air hose fitting confusion [Re: billt460] #5234535 10/09/19 07:01 AM
Donald Online Content
Online Content
Thanks.
Actually this is not 100% correct. Having a single 1/2" ball valve does not mean there will not be additional restriction imposed by using 1/2" hose vs 3/4" hose. In his case it will be hose he installs once and never moves or caries so weight and bulkiness is not an issue.
Having said that I assume 1/2" hose will be fine.
2015 Ford F-250 w/Powerstroke
Re: Air hose fitting confusion [Re: dlundblad] #5234537 10/09/19 07:02 AM
Online Content
Depending upon the air tool, there are high performance quick connect couplers that restrict less than the normal ones. I think from memory its Milton V
Re: Air hose fitting confusion [Re: Donald] #5234577 10/09/19 07:45 AM
demarpaint Offline
Milton V is the one. thumbsup
God Bless Our Troops
Re: Air hose fitting confusion [Re: Donald] #5234686 10/09/19 09:19 AM
B
billt460 Offline
B
Good point. Even the best, (read largest I.D.) quick disconnect fittings restrict flow by having a much smaller I.D. than the hose that feeds them.
Re: Air hose fitting confusion [Re: Donald] #5235071 10/09/19 04:30 PM
Thanks. This is my next step as I believe my Aircat 1150, as well as all my other lesser important pneumatics, have 1/4” fittings.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Air hose fitting confusion [Re: dlundblad] #5235094 10/09/19 05:06 PM
demarpaint Offline
You will notice a big improvement.
