Forums Migration
Please read this thread
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
108 registered members (77Se7en, 2018matto, Aichiguy, 87sammy, 2002 Maxima SE, Alfred_B, 11 invisible), 2,022 guests, and 31 spiders.
Topics307,777
Posts5,317,599
Members71,917
Change it up or stick to 0W20? #5234101 10/08/19 05:45 PM
M
mobilaltima Offline OP
M
Two cousins with the same truck, one is a 2017 1500 Chevy with the 5.3 Ecotec 32k miles, the other is a 2018 with 15k. They both travel 60 miles round trip each day to work all highway miles. I have been using Supertech Dexos 0W20 with an Ac Delco filter on both at 6-7k intervals. Should I stick to the 0W20 or would it be of any benefit to start using either Mobil 1 AFE 0W30, which is Dexos approved, or Supertech 5W30 syn, which is Dexos approved also. They have both been running great on the spec'd oil.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234107 10/08/19 05:48 PM
J
JLTD Offline
J
popcorn
How do they UOAs look?
Lates.
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234115 10/08/19 05:55 PM
T
tig1 Offline
T
My son uses M1 0-20EP in his GMC Denali V8. He changes every 15K with 95 K on his 2016 and 25K on his 2019.
2007 Ford Fusion 260,000 miles
M1 5-20HM
2017 Ford Fusion 93K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234148 10/08/19 06:15 PM
Z
Zolton Offline
Z
Simple, just ask "why" 0w-20. Is there a good reason? Oh, save .001% mpg and risk engine wear, ok.
Re: Change it up or stick to 0W20? [Re: Zolton] #5234154 10/08/19 06:19 PM
PimTac Offline
Hogwash.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234158 10/08/19 06:22 PM
Rat407 Offline
I would stick to what you are doing. Considering those have a 2 gallon sump and changing out at 6-7k miles the oil is just fine and as for wear, not even an issue.
2014 Cruze Diesel 5w-30 AMSOIL
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234171 10/08/19 06:35 PM
N
NormanBuntz Offline
N
The question I'd ask myself is why do I need a 0w-xx oil in Louisiana? Personally I'd use a 5w-20, save some bucks and sleep well at night.
"Hot dog! Groat cakes again. Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 13K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234173 10/08/19 06:36 PM
R
Railrust Offline
R
I have a 2018 with 38,000 miles and I'm starting to wonder the same thing (I've been running the 0w20 since new for 5,000 mile intervals). I've used Pennzoil Platinum, Rotella Gas Truck and Super Tech (for one run). Thinking of switching to a 5w30.
Truck does use a little oil between changes...maybe 3/4 of a quart in 5,000 miles. I've yet to see a 5.3 Ecotech that doesn't use some oil.
2018 Chevy Silverado 5.3 (sold, with 52,000 stumbling and bumbling miles)
2007 Lexus LS460 (deceased)
2008 Honda CRV
2016 Toyota Avalon XLE
(Whatever synthetic oil is on sale or rebate)
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234180 10/08/19 06:43 PM
4WD Offline
I have two of them - they don't use oil. Running M1 AFE 0w20 now … but bought M1 AP on clearance and will stay with 0w20 for a while
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234188 10/08/19 06:50 PM
Z
zfasts03 Offline
Z
Ran Mobil1 0w-20 AFE for the 1st 12,000 or so.
Now running Amsoil 0w-20 SS in my `16 Suburban, just following the OLM and a Fram XG10575. Probably keep up with this for the extent of ownership.
Big sump 8 qts. and and oil cooler. 0w-20 is fine.
Another vehicle I have that will rust away before it wears out.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234203 10/08/19 07:05 PM
M
M
My question is, should a problem arise, would the warranty still be honored being a Dexos oil is used, even if its a non spec'd 30 weight?
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234204 10/08/19 07:06 PM
M
M
Id use nothing but the Fram XG10575 if it had the proper bypass psi.
Re: Change it up or stick to 0W20? [Re: Zolton] #5234229 10/08/19 07:33 PM
G
Greggy_D Offline
G
Prove it.
Greggy D.
Re: Change it up or stick to 0W20? [Re: mobilaltima] #5234230 10/08/19 07:34 PM
Z
zfasts03 Offline
Z
The new Fram XG 10575 has the the proper by-pass of 16-28 psi. You can tell the new stock from old by looking at the by-pass valve down at the center of the filter. The new ones are white. The old stock is black.
New ones have been out since ~April.
I know the boxes are sealed. I just carefully open and check it out. I think 9/10 by now most stock is new, especially at WalMart.
- 03 Corvette Z06
Amsoil 5w-30 SS
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Re: Change it up or stick to 0W20? [Re: NormanBuntz] #5234262 10/08/19 08:23 PM
T
tiger862 Online Content
Online Content
T
5w20 is same price. 0w20 in Louisiana will fine as sister runs this oil in an Altima. Not enough difference between 0 or 5 nor is there much of difference between 20 grade and 30 grade whether wear or fuel mileage. If you want to save on oil go Havoline ProDs route just buy 2 boxes then save extra since it is 6 qt
boxes
Tiger862
2018 Grand Caravan
