Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
23 registered members (Danno, blufeb95, Char Baby, Blueskies123, ctechbob, bbhero, 2 invisible), 711 guests, and 50 spiders.
Topics306,079
Posts5,286,975
Members71,596
New Renegade 1.3L Turbo oil/breakin #5234193 10/08/19 06:54 PM
H
HoosierJeeper Offline OP
H
Picking up my new Jeep Renegade Trailhawk with the 1.3L turbo. I believe it calls for 0w30. What are the thoughts on breaking it in? Baby it? Drive it hard? Mix? Is driving it on the highway a few hours bad for it? (through some rolling hills)? How long to leave the factory oil in?
For the oil choice, I'm thinking Pennzoil Platinum in the 0W30. But open to other ideas.
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234212 10/08/19 07:17 PM
H
HyundaiAbuser Offline
H
You're supposed to vary the rpms without pushing it too hard. Check the owners manual for what it specifies on procedure (if it does). If it were my car I would change the oil at 500 miles, then again at 2k and again at 5k. From there its really up to you (and your warrantee) on how often you change it. Another thing I would do is have the transmission fluid changed at around 15k to clear any break in debris. Some say its not worth doing and some say its an absolute must, just something I'd recommend for comfort. As for oil pretty much any sn+ will do you well I haven't read up too much on Pennzoil platinum but if you're confident in it run it. Some other good shouts are mobile 1 for the reputation of a very clean engine (even better starting from new) and the castrol edge and magnatec series have shown some good UOAs.
And its recommended not to sit at the same rpm for long periods of time for what that's worth, so I would say long highway driving is not a go yet.
03 Hyundai Tiburon:
PP High Mileage 5w30
Redline MT85
94 Mazda B4000
Supertech 10w40 High Mileage (RIP)
Valvoline Maxlife
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234213 10/08/19 07:17 PM
Z
zfasts03 Offline
Z
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234214 10/08/19 07:19 PM
PimTac Offline
Any major brand of oil that meets specs will run fine.
Drive normally, drive sensibly.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234225 10/08/19 07:30 PM
Z
zfasts03 Offline
Z
The ACEA C2 / API SN spec is required. Not sure if one or both...
This 0W-30 MOTOR OIL - RAVENOL FES has the C2 spec!
- 03 Corvette Z06
Amsoil 5w-30 SS
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234233 10/08/19 07:41 PM
B
buster Offline
B
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5209851/1
I would say don't baby it, but don't run it too hard either. I think a few good WOT runs between 2-4k or 2-5k rpms is good for seating the rings. You don't want to maintain any constant speed at a given RPM. It's easier to do with a manual transmission.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234239 10/08/19 07:50 PM
doitmyself Offline
Here's what my 2014 FCA Jeep vehicle recommends: "Drive moderately during the first 300 miles (500 km). After the initial 60 miles (100 km), speeds up to 50 or 55 mph (80 or 90 km/h) are desirable.While cruising, brief full-throttle acceleration within the limits of local traffic laws contributes to a good break-in.Wide-open throttle acceleration in low gear can be detrimental and should be avoided.
Does the current owner's manual still have that "full throttle acceleration" recommendation in it?
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234240 10/08/19 07:51 PM
K
kstanf150 Offline
K
Drive it like your gona drive it everyday from now on
I’ve bought over 50 new vehicles and breaking in a new engine isn’t rocket science.
They come from the factory pretty much pre-seasoned to last a long time
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234251 10/08/19 08:13 PM
H
H
I'm guessing it'll have about 250 miles on it when I get it. How long does the period last?
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234302 10/08/19 08:57 PM
J
jqgz Offline
J
I would avoid holding a set speed for more than 15 min for the first week or so. Also, let it idle for at least 15 seconds after you start it to get oil pressure, and the same before shutting off so the turbo can slow down. But, avoid extensive idling as it's not good for the engine.
Avoid over 3500 rpm, change oil at 2500 miles, you'll be just fine driving it normally.
Mobil 1 AFE comes in a 0w-30. If you can't find it, Pennzoil Ultra is a great oil and a 5w-30 on the thin side of the spectrum.
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234414 10/09/19 12:50 AM
O
oldhp Offline
O
The ring and pinion breaking in is more important to me. I'm pretty sure that's why the first 300 miles is important. Some cooling down cycles helps the rear gear. So really your breaking in all the drive train together for the first 300miles.
I change the rear gear oil between 500-1000'ish miles.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234492 10/09/19 06:05 AM
CT8 Offline
Engines have no choice but to break in, just drive it . No voo doo needed
2015 F150 2.7
2018 F350 6.2
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234533 10/09/19 06:59 AM
H
H
What is the MS-13340 spec? Looks like that and 0W30 are the only things it needs. Figure I'll stick with stuff that meets that spec while it's under warranty.
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234573 10/09/19 07:38 AM
K
ka9mnx Offline
K
OM should tell you how to break it in.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: New Renegade 1.3L Turbo oil/breakin [Re: HoosierJeeper] #5234615 10/09/19 08:17 AM
B
buster Offline
B
You can put load on the engine without bringing rpms high and that is ideal IMO. Engines today don't require an elaborate break-in. The main thing you want to avoid which is the common denominator you read about is sustained RPMs and sustained high rpms. Keep the engine rpms moving around between 2-4k and you're good. You can give it WOT too as long as you let it cool down. My . 02
