How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
76 registered members (97prizm, 1978elcamino, 2015_PSD, 53' Stude, 73guna, aba4430, 7 invisible), 1,852 guests, and 18 spiders.
Topics306,113
Posts5,286,738
Members71,588
hybrid oil change interval #5234071 10/08/19 04:59 PM
W
WhyMe Offline OP
W
my sons ioniq has 1500 miles on it already. Hyundai states 7500 oil changes. same mileage as the Tucson we have. seeing that the hybrid ICE only runs at certain times , does it really need to be changed at 7500 hybrid miles?
i will follow the factory oil change interval for sure to make sure the warranty is valid though.
Re: hybrid oil change interval [Re: WhyMe] #5234075 10/08/19 05:01 PM
JohnnyJohnson Online Content
Online Content
Only if you want a warranty.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: hybrid oil change interval [Re: WhyMe] #5234079 10/08/19 05:06 PM
T
tahoe_hybrid Offline
T
4000OCI miles is what i do, if you want to keep the engine clean for the whole time you have it
Re: hybrid oil change interval [Re: WhyMe] #5234080 10/08/19 05:06 PM
Bud Offline
Just follow the owners manual.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: hybrid oil change interval [Re: WhyMe] #5234087 10/08/19 05:14 PM
A
azjake Offline
A
I have a Kia Niro which is the same powertrain as the Ioniq. FWIW. The Kia dealer where I get it serviced is recommending a 6 month, 5000 mile OCI.
2019 Kia Niro EX w/Premium pkg.
Re: hybrid oil change interval [Re: WhyMe] #5234099 10/08/19 05:43 PM
P
PandaBear Offline
P
Depends on how is the fuel dilution. Sometimes they run the engine colder than others and with direct injection it can push the fuel dilution over the edge. I'd stick with no more than their recommendation until more data is out (i.e .when the power train is 8 years old and finally starts to see issues) before attempting something risky.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: hybrid oil change interval [Re: WhyMe] #5234106 10/08/19 05:47 PM
J
JLTD Offline
J
Unless you're on the highway a lot, that engine will be started more frequently. I'd consider going with mfg recommendation, but temper that with a UOA or two in order to insure that [i]your]/i] oil is being used for a proper interval.
Lates.
Re: hybrid oil change interval [Re: WhyMe] #5234117 10/08/19 05:56 PM
R
Rmay635703 Offline
R
If it’s truly a hybrid and not a plug in you may find you need to change more often than Hyundai recommends
Many hybrids run in short trips with minimal highway start burning oil
Re: hybrid oil change interval [Re: JohnnyJohnson] #5234168 10/08/19 06:31 PM
G
Gebo Online Content
Online Content
G
banana
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: hybrid oil change interval [Re: WhyMe] #5234185 10/08/19 06:48 PM
PimTac Offline
Think about it, if the engine runs half the time then that’s less than 4000 miles. Follow the manual instructions. Why second guess it?
HMS
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: hybrid oil change interval [Re: WhyMe] #5234192 10/08/19 06:54 PM
T
T
7500 miles is to make the engine last to 100k
if you want it to last much longer you need a lower OCI smile
dirty oil causes:
broken hoses
failed seals
failed engine components ..
sludge
4k oci should get it to 250k or more
do you have the DOHC vvt then yes 4k OCI
also only use top tier gas
Re: hybrid oil change interval [Re: WhyMe] #5234244 10/08/19 08:01 PM
cpayne5 Offline
My daily driver has 268k miles on it - I bought it with 10k on it 11 years ago. I change the oil when the dummy light comes on - usually around 7500 miles. It runs great, and is much cleaner under the valve cover than you would expect. It's a high revving, DOHC vtec engine, too.
Stop with the "the world will end if you go beyond 4k OCIs". It's a bogus, blanket statement.
Re: hybrid oil change interval [Re: WhyMe] #5234245 10/08/19 08:01 PM
N
NO2 Offline
N
Follow Hyundai's recommendation and be done with it. Saying a 7500 mi OCI will cause excess wear is just ridiculous.
Re: hybrid oil change interval [Re: WhyMe] #5234858 10/09/19 12:10 PM
cjolson140 Offline
I remember people recommending 10k+ OCIs on Priuses a few years back, with the same logic of “the engine doesn’t run that often!” Now many priuses with less than 200k miles are using a quart every 1000 miles due to stuck oil rings and blocked piston drains.
Specifically a design issue with the 1nz-fxe engine in that case (same as 90s Saturns), but why risk it?
Re: hybrid oil change interval [Re: WhyMe] #5234916 10/09/19 01:10 PM
N
nthach Offline
N
I stick to 5K max on Toyota hybrids. The engines on those don't get the benefit of a proper break-in due to how hybrids operate. My hypothesis to why a Prius will burn oil sooner than a Yaris/Echo/Corolla is the engine stops when there is an deceleration event. In a normal car, the engine still spins without fuel. In a Prius, the engine falls to 0RPM and the hybrid ECU commands regen mode.
If I had to do it again in a Prius, I'd drive the car in PWR mode and engage B mode which does spin the ICE for the first 1K of that car's life. At least that will give the rings a fighting chance to break in and seal.
