Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
106 registered members (ArrestMeRedZ, 2015_PSD, Anduril, another Todd, 4WD, aquariuscsm, 10 invisible), 2,126 guests, and 70 spiders.
Topics306,138
Posts5,288,212
Members71,604
Concrete question #5234028 10/08/19 04:07 PM
007 Offline OP
I am looking to build a new home in Central Florida. I see that some builders use 2500 psi concrete and others use 3000 psi for the slab, garage and sidewalks. Is there much of a difference in as far as finish, cracks and cost?
Re: Concrete question [Re: 007] #5234072 10/08/19 04:59 PM
spasm3 Online Happy
Online Happy
For my drive, i used 3500psi with fiber. Does not seem to finish quite as smooth, but i was broom finishing it anyway.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Concrete question [Re: 007] #5234111 10/08/19 05:52 PM
J
JTK Offline
J
The quality of the base, prep, materials, installation and finish work matters more than the psi for this application IMO.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Concrete question [Re: 007] #5234149 10/08/19 06:15 PM
Z
Zolton Offline
Z
Use the best mix, you won't regret it.
Re: Concrete question [Re: Zolton] #5234179 10/08/19 06:43 PM
B
bcossa2001 Offline
B
Commercial contractor here. Use 3000. I’m guessing the cost difference to be on the order of $2 to $5 per yard.
"Facts are pesky things"
2003 Town & Country--143 k
2016 Fusion 8 k
2016 Fusion 40 k
2017 Santa Fe 8k
Re: Concrete question [Re: 007] #5234196 10/08/19 06:57 PM
B
bubbatime Offline
B
I just bought a new house that was built in 2016. The driveway is all cracked to heck and back. Its terrible. I have to replace it. knowing the folks that built the house, they went cheap on everything as they were low on funds, so they probably went with the cheap concrete as well, and poured it thin. Id opt for the better concrete when it comes time to replace it.
Re: Concrete question [Re: 007] #5234197 10/08/19 06:58 PM
M
madRiver Offline
M
The contractor more important then 500 psi.
Re: Concrete question [Re: 007] #5234200 10/08/19 07:02 PM
K
kstanf150 Offline
K
If your building a home from the slab up
I’d get the highest PSI concrete I could afford
5000 🤔🤔🤔
Re: Concrete question [Re: 007] #5234219 10/08/19 07:25 PM
69GTX Offline
When I was sending out bidding contracts for our main concrete plant floor slab that was subjected to bucket wheel loaders up to a CAT 966 we went for 4000 psi concrete. We saw a couple hundred heavy trucks a day on that floor delivering 400 tons in materials each day. Another point to consider is whether you are using quick set or longer setting concretes. Some can be ready for traffic in 24 hrs and others will take days. Full compressive strength typically not reached for 30 days or more. For a foundation I would think quick setting is needed to fit the construction schedule. Improper mixing, surface prepping of the concrete can lead to spalling, cracking, and other issues down the road.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Concrete question [Re: bubbatime] #5234270 10/08/19 08:26 PM
O
OilReport99 Online Content
Online Content
O
Similar experience here. Bought it new in 2018
2018 Ram 1500 - VME 5W-20
Re: Concrete question [Re: madRiver] #5234278 10/08/19 08:35 PM
U
user52165 Offline
U
+1 This
Re: Concrete question [Re: JTK] #5234280 10/08/19 08:36 PM
U
user52165 Offline
U
+1 this
Re: Concrete question [Re: 007] #5234365 10/08/19 10:26 PM
M
MNgopher Offline
M
Base, prep, and finish will make more of a difference than 500 psi in the concrete. Make sure the contractor does quality work!
The contractor who did my driveway had a stellar reputation, and they and the earthmoving sub they used were great. They made sure to compact the base amazingly well - and everyone involved commented that without it the rest of the work would be junk. 10 years later, not a single crack in the driveway, even on the fill sections.
Here, 3500 psi or 4000 psi concrete is typical for driveways. This will vary across the country dependent on source materials and climate, so the lower numbers would be odd here, but perhaps they are normal there...
Re: Concrete question [Re: 007] #5235107 10/09/19 05:29 PM
007 Offline OP
In my case I am dealing with a new home builder in a brand new neighborhood. On the spec sheet it says they use 2500 psi concrete. All the homes there now are to new to see any issues. Just remember being told back in the day to use at least 3000 psi. Builder says he can but has not given me the extra cost yet.
Re: Concrete question [Re: bcossa2001] #5237259 10/11/19 05:18 PM
SVTCobra Offline
I just poured concrete piers for a new barn. I had the same question and used 3000, the extra cost was a whole $3 a yard. If the contractor quotes more than $5 per yard I'd call around to get your own quotes.
Think twice, speak once.
