Forums Migration
Please read this thread
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
Beater trifecta
by Red91 - 07/11/20 01:08 PM
ILoveOil111, quantalume, SUmeme22, DaveCaddell, SharkNC
71909 Registered Users
90 registered members (92saturnsl2, Alaskanmont, 2strokeNorthstar, aba4430, Aichiguy, 2010Civic, 4 invisible), 1,408 guests, and 27 spiders.
Topics307,744
Posts5,316,900
Members71,909
Oil Degreaser For 2 Stroke Outboard Water Passages #5233959 10/08/19 02:46 PM
F
Fitz98 Offline OP
F
I have a 2001 Optimax 200 2 stroke.
Over the years a bunch of oil and thick sludge has built up in the exhaust plate and blocked some of my water passages. I was able to degrease the majority of the exhaust plate through the midsection by removing the lower unit and spraying up inside and using a copper wire to help unclog some of the coolant passage holes. Now I want to go the rest of the way and degrease those ports through the cooling system flushing ports.
Anyone have any experience or advice on product or procedure to do this?
Here is a picture looking up the mid section, what you can't see are the 4 coolant passages covered with old crusty oil
[Linked Image]
Re: Oil Degreaser For 2 Stroke Outboard Water Passages [Re: Fitz98] #5233970 10/08/19 02:58 PM
R
ragtoplvr Offline
R
If you have that much build up I think an inspection of the exhaust ports would be wise. You might be losing some horsepower.
Rod
Re: Oil Degreaser For 2 Stroke Outboard Water Passages [Re: Fitz98] #5234094 10/08/19 05:29 PM
1
1978elcamino Offline
1
I would think those passages look normal for a two stroke and probably not worry about it. I would be more concerned about the water passages getting clogged up with debris and salt. Personally, I have ran a high concentrate of vinager and water through the motor with an electric pump for hours and that cleaned out all kinds of crud from the cooling system.
