Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
81 registered members (ABN_CBT_ENGR, aba4430, andyd, AdditiveOCD, 1foxracing, 2003f7, 11 invisible), 1,785 guests, and 34 spiders.
Topics306,112
Posts5,286,717
Members71,588
asphalt driveway sealer #5233854 10/08/19 12:23 PM
Donald Offline OP
Well despite my best efforts I will not have time to apply the Rustoleum Epoxy driveway sealer at my DE home this year and its getting to the end of the season where its warm enough.
My son-inlaw is in the business in CT (Renew Asphalt Maintenance) but too far to drive his truck. But gives me suggestions. He suggests petroleum resin driveway sealer as the best and no environmental issues like with coal tar. Also in the running is asphalt emulsion.
Try to find some contractor who can apply or even has petroleum resin and I come up with none. Same for asphalt emulsion.
Now some use Gilsonite but I hear that is mostly gypsies and they thin it down a lot with whatever is cheapest at the gas station vs mineral spirits.
Looks like if I want it sealed this year it will be coal tar sealer.
Disappointed that more people do not care about the environmental concerns with coal tar and force the contractors to get better products for the environment.
I assume most people just want their driveway sealed vs investigating the product being used.
2015 Ford F-250 w/Powerstroke
Re: asphalt driveway sealer [Re: Donald] #5233921 10/08/19 01:49 PM
SeaJay Offline
The most important thing is to do it regularly, like every other year or so rather than trying to get the perfect product. I don't do many home projects myself because of a lack of skill for many repairs. But resealing my driveway is one that I do myself since it is mostly labor with close to zero skill required, a couple of 5 gallon buckets is enough for my driveway
The standard home depot stuff I use says it is good for 7 years, or something like that. But I try to do it every other year, or every third year at the most. Like you, I am in a cold northeast location with freezing snow and rain trying to create cracks every winter, and I don't trust the 7 year expected lifespan of the sealer.
Re: asphalt driveway sealer [Re: Donald] #5233960 10/08/19 02:47 PM
diyjake Online Content
Online Content
Most homeowners probably don't even know there are other options besides coal tar. Usually whatever is cheap and fast is what is used.
Re: asphalt driveway sealer [Re: Donald] #5233965 10/08/19 02:52 PM
supton Online Content
Online Content
I was meaning to do this project this year, but kept missing it. I haven't even looked to see what my options are. Other than to assume it's too late in the season to bother. So I'll pay attention to this thread. wink
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: asphalt driveway sealer [Re: Donald] #5233971 10/08/19 02:59 PM
J
JTK Offline
J
I haven't read up on it, but what's more ecologically friendly about dumping an epoxy resin on the ground over using coal tar that dries rock hard within an hour or two? Sounds more like a marketing thing to me.
After all, all you are doing is putting a coating on inches thick worth of a petroleum product (asphalt) that is in direct contact with the ground.
FWIW, I prefer coatings like a coal tar emulsion. I had an ~18'x120' portion of my driveway done for $165 a few weeks back. I can't do it myself with 5gal store bought pails for that.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: asphalt driveway sealer [Re: Donald] #5233986 10/08/19 03:16 PM
B
billt460 Offline
B
When I had a blacktop driveway in Illinois, I always used nothing but Sakrete Coal Tar Sealer. It worked beautifully. I put it down every year for 2 years. Then every other year. The first application took 7 buckets. The second took 4. From then on it only took 2 to do the entire driveway. I had the nicest driveway on the block. There wasn't a crack in it.
Re: asphalt driveway sealer [Re: Donald] #5234003 10/08/19 03:36 PM
69GTX Offline
Whatever they sell at HD or Lowe's, it's lucky if it lasts 2-3 yrs in New England. And if you shovel frequently only 1-2 yrs. I only have a 10x55 ft driveway....and I can't get any driveway contractor to reseal it for less than $330. So I buy a single $25-$30 bucket of sealer and apply it myself every 1-2 yrs. Whatever the contractors use around here looks more rugged than what I buy. It certainly doesn't dry hard as rock as it takes several days before you can drive over it without leaving tire prints. And if you drive through it wet at any time after it's cured, you leave 'sandy' tire tracks behind. I applied mine a month ago and I still see fresh animal prints on it from the morning dew.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: asphalt driveway sealer [Re: Donald] #5234011 10/08/19 03:41 PM
spavel6 Offline
Why not pave the driveway so you don't have to dump a strange chemical on it?!
After all, anything you put over the asphalt is just a short-term band-aid..
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: asphalt driveway sealer [Re: spavel6] #5234025 10/08/19 03:57 PM
Online Content
I think we're missing something here... asphalt driveway sealer is put over paved driveways.
Re: asphalt driveway sealer [Re: supton] #5234052 10/08/19 04:35 PM
PimTac Offline
If he is thinking of paving over the asphalt then good luck with that. It’s not as simple as that. Consider your clearances to the garage and street.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: asphalt driveway sealer [Re: 69GTX] #5234096 10/08/19 05:38 PM
J
JTK Offline
J
One 5gal bucket does your 10'x55' driveway? Contractors in the Buffalo area vary quite a bit on price too. This year was was a good $40-50 cheaper than what I paid 3yrs ago. I have to re-do mine about every 2yrs.
I realize my driveway is larger and perhaps we're comparing different materials, but the contractors use about 8-10 full 5gal buckets on mine and it's good to drive on in 24hrs. No tracking onto the concrete up by the house at all. At that point, only pockets where the material has pooled will still be soft.
Re: asphalt driveway sealer [Re: Donald] #5234147 10/08/19 06:15 PM
CT8 Offline
What is Asphalt made from ?
2015 F150 2.7
2018 F350 6.2
Re: asphalt driveway sealer [Re: Donald] #5234174 10/08/19 06:37 PM
T
twouvakind Offline
T
This is a basic description of hot mix asphalt. Your mix may vary.
Aggregate
Asphalt Cement
Crystalline Silica (Quartz)
Hydrogen Sulfide
Additives
Just put the friggin' Maxlife in and be done with it!
Re: asphalt driveway sealer [Re: JTK] #5234211 10/08/19 07:16 PM
69GTX Offline
Yeah, less than 1 bucket of HD/Lowe's stuff on mine. And it can be spread quite thin in order not to pool it These require a slightly moist surface or they will not spread....like using molasses. NO doubt whatever the contractors use it's a higher grade and will last longer. Their finished product looks better too. I can possibly drive on mine in 24 hrs but have never dared try that. It dries to foot traffic in 3-6 hrs on a hot day. But again, get it wet and walk and drive on it, and the sand that's part of the mix leeches out....always.
1969 Ply GTX/RRs
Re: asphalt driveway sealer [Re: JTK] #5234341 10/08/19 09:44 PM
Donald Offline OP
Here is what they say about coal tar (banned in some states/localities)
There is a hidden and longer term health issue with certain types of driveway sealant – they break down over time from cars being driven on them and from weathering. If the driveway sealant is made from coal tar, this break down can release chemicals called polycyclic aromatic hydrocarbons (PAHs). These chemicals are carcinogenic and are already in the environment as part of air pollution. However the additional amount from driveway sealant can produce local contamination that can be a health concern. The United States Geological Survey (USGS) has shown that the dust on parking lots and driveways sealed with coal tar-based products can be high in PAHs. Of further concern is their finding that this contamination can extend into nearby homes and create high levels of carcinogenic PAHs in house dust. Fortunately, asphalt-based driveway sealant is an alternative to coal tar products. It coats well and does not contain PAHs making the asphalt product safer and better for the environment.
