How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
73 registered members (2015_PSD, 53' Stude, andyd, 73guna, ABN_CBT_ENGR, aba4430, 9 invisible), 1,741 guests, and 29 spiders.
Topics306,113
Posts5,286,731
Members71,588
Can different oil affect exhaust smell? #5233840 10/08/19 12:08 PM
rsylvstr Offline OP
Flame suit on.
Normally I run MC blend 5w20 in my 2013 F150 5.0 with 62k.
Changed to the Havoline I had sitting around (red bottle HM) 5w20 and after about 500 miles the exhaust just smells strong.
Not like gas, sulfur or anything I can pinpoint.
No codes. No idle or running issues.
Just strong.
Is it the oil or NY winter fuel? 93 octane with OZ Omega tune.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5233887 10/08/19 12:54 PM
R
ragtoplvr Online Content
Online Content
R
check to make sure the PVC is working and not venting oil into the intake.
Rod
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5233888 10/08/19 12:57 PM
B
BillyE Offline
B
Yes it can. Of course, it makes more sense if you're burning oil, as Rod pointed out.
Re: Can different oil affect exhaust smell? [Re: ragtoplvr] #5233917 10/08/19 01:43 PM
rsylvstr Offline OP
I have an oil separator.
Emptied at oil change but should check it again.
Didn’t have much when I emptied it but that was a different oil.
PCV valve is new and seemed to be working. Good idea though.
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5233924 10/08/19 01:57 PM
R
Online Content
R
It is well known fresh oil will help you pass a tailpipe emissions test.
Rod
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5233949 10/08/19 02:33 PM
M
Mad_Hatter Offline
M
I have bad allergies so I don't know what "good" oil smells like.😖
Re: Can different oil affect exhaust smell? [Re: ragtoplvr] #5234032 10/08/19 04:15 PM
rsylvstr Offline OP
It is fresh oil
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5234069 10/08/19 04:51 PM
Q
Quest Offline
Q
If you are able to smell the difference (of motor oil brand/type) from the exhaust, then you have a genuine mechanical issue (engine burning or passing oil into exhaust).
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5234085 10/08/19 05:13 PM
caprice_2nv Offline
Originally Posted by rsylvstr
Flame suit on.
Just strong.
Either in your head (you all of a sudden became more sensitive to exhaust smell) or possibly the winter gas if you really are that sensitive to smell.
I can't smell a difference and I drive old carbureted v8s. One that was leaking like crazy from the valve cover gaskets. It smelled like oil no matter what. Maybe some people sharper than I could smell the difference from one to the other, but that was an extreme case, oil leaking directly into the manifolds.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5234108 10/08/19 05:48 PM
rsylvstr Offline OP
Interesting.
Will report back if anything changes.
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5234252 10/08/19 08:13 PM
A
AVB Offline
A
I haven't ever noticed a difference in the exhaust smell, but I have noticed a diesel engine smell different after changing the oil. I pointed it out to my coworker and he said John Deere oil had a strong smell like that too. The smell must have been coming out through the crankcase vent even though it was a closed system.
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5234291 10/08/19 08:47 PM
B
BillyE Offline
B
A lot of people claim Rotella makes their diesels stink. Might only apply to DPF regens though.
Re: Can different oil affect exhaust smell? [Re: rsylvstr] #5234466 10/09/19 04:54 AM
rsylvstr Offline OP
Thanks.
Definitely doesn’t smell like oil burning.
