bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
13 registered members (Darren_L, 4WD, Duke, Dunkaroo, dlundblad, Backwoods41695), 752 guests, and 44 spiders.
Topics306,116
Posts5,287,808
Members71,604
Page 1 of 4 1 2 3 4
Pulsating brakes/shaking steering wheel #5233775 10/08/19 11:07 AM
G
greasegunn Offline OP
G
I’m having an intermittent shaking steering wheel and brake pulsation problem on my 2008 Honda Accord with 125,000 miles. The rotors and pads where replaced approximately 6 month/6,000 miles ago. I used pads and rotors that have performed well for me several times in the past (did not use “economy” parts). Any help in diagnosing the problem will be greatly appreciated. Here are some of my observations:
• Pulsation /shaking does not always occur immediately and when it occurs it is not always to the same degree or magnitude
• Pulsation /shaking does occur on every trip
• Pulsation /shaking only occurs when braking
• Checked front slider pins and they move freely
• Front brake pads are worn evenly
• There is no pull when braking or driving
• Steering appears to be behaving properly
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5233784 10/08/19 11:12 AM
slacktide_bitog Offline
What do the rotors look like? Any prominent lines in the rotors?
Does the shaking vary with the speed you're stopping from?
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5233798 10/08/19 11:21 AM
M
MParr Offline
M
Sounds like a warped rotor to me. Check for runout. Have you had new tires mounted or rotated since the brake job? Over tightening can warp them.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: Pulsating brakes/shaking steering wheel [Re: slacktide_bitog] #5233799 10/08/19 11:23 AM
G
G
Rotors look OK - plan on measuring thickness this weekend. No lines, scuffs, pits. Worn evenly on both sides
Shaking/pulsation seems to be worse on light to medium braking and then tends to lessen as brakes are applied more strongly. High speed seems to be worse but I think this may be related to the number of wheels rotations per time
Re: Pulsating brakes/shaking steering wheel [Re: MParr] #5233801 10/08/19 11:25 AM
G
G
I will ck the run out this weekend. Had new front tires put on a couple of months ago due to a flat.
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5233817 10/08/19 11:41 AM
M
MParr Offline
M
Measuring the thickness isn’t going to tell you if they are warped. Lines, scuffs or pits will not tell you if they are warped. You are going to have to put a dial indicator or makeshift tool on the rotors and slowly rotate them. I’m willing to bet the wheels were over torqued when the tires were mounted.
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5233821 10/08/19 11:44 AM
domer10 Offline
I would say warped rotor, this is why I do not cheap out with rotors anymore. I know you said you did not, but from experience this sounds like a warped rotor. The junk metal is proliferating into the mid level options for parts with certain manufacturers unfortunately.
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5233830 10/08/19 11:55 AM
Q
Quest Offline
Q
did you do the brake job with fresh new rotors, or did you simply slap on a new set of pads w/o re-surfacing the rotors and/or checking for trueness?
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5233844 10/08/19 12:15 PM
M
mclasser Offline
M
Could also be pad material deposition on the rotors. Try going out to an empty road and bed the pads in again.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Pulsating brakes/shaking steering wheel [Re: mclasser] #5233857 10/08/19 12:26 PM
N
nthach Offline
N
Some brands of brake pads are worse than others for that - but most NAO friction work via cohesive friction, meaning the pads leave a transfer film of friction on the rotors. Akebono pads are own to leave heavy deposits but I've never had "warped" rotors from them.
However, besides from turning rotors the only way to really remove that film of friction are semi-metallic brake pads. Mercedes used to have in their tools/materials catalog a set of "cleaning" pads that were installed in place of the regular pads. You drove the car around the block or for a few miles gingerly, and swap in the regular pads.
That's why I'm not a fan of turning rotors unless they are OEM and you have access to a on-car lathe. A off-car lathe is "true" to the naked eye but there's the issue of lateral run-out. By the time you take off material to resolve any warpage or other issues, you can be close or above the max spec for thickness and introduce more issues.
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5233861 10/08/19 12:28 PM
K
krismoriah72 Offline
K
Put your hand on the front wheels after normal driving..if wheel is scorching hot then suspect caliper/hose which in turn warps rotor.
Re: Pulsating brakes/shaking steering wheel [Re: krismoriah72] #5233868 10/08/19 12:35 PM
domer10 Offline
OP should see if he has access to a temp gun. Take a reading after driving around the block a few times with heavy brake applications.
2001 Toyota 4Runner
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5234014 10/08/19 03:43 PM
spavel6 Offline
Check that your inner tie-rods are nice and tight, as well as control arm bushings, etc.
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Pulsating brakes/shaking steering wheel [Re: domer10] #5234037 10/08/19 04:19 PM
K
K
Well if a caliper is sticking..then no need for heavy brake applications..
Re: Pulsating brakes/shaking steering wheel [Re: greasegunn] #5234067 10/08/19 04:47 PM
W
Warstud Offline
W
Were the Lug Nuts torqued to the proper spec?
nut
Page 1 of 4 1 2 3 4
