bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
18 registered members (Char Baby, FirstNissan, FordCapriDriver, FT92, GMguy84, 1 invisible), 756 guests, and 44 spiders.
Topics306,116
Posts5,287,808
Members71,602
2010 Traverse, Valvoline Maxlife 5W-30, 4,909 #5233758 10/08/19 10:54 AM
R
rbarrios Offline OP
R
This is for my 2010 Traverse. Oil sample taken at 152,653.
Ive included all of my UOA.
My interest in the UOA- is to monitor for elevated iron levels-- pointing to timing chain wear.
As can be seen the engine now uses more oil. I check the oil levels weekly and make sure its stays up.
Seems that folks with these engines- who do not monitor oil levels-- end up with worn chains.
The current oil now in use is Valvoline Max-life 5W-30 for high mileage engines.
All other UOA are Valvoline Conventional 5W-30.
I began to transition over to Maxlife with previous oil changes.... something like this.
3 qts VWB and 2.5 qts max-life
2 qts VWB and 3.5 qts max-life
1 qt VWB and 4.5 qts max-life
5.5 qts maxlife.
Im guessing carbon buildup. Pieces have broken off and scratched the inside of the cylinders causing zebra stripping- leading to oil use.
The vehicles current weekly driving is---
5 mile drive in the AM- 15 min at most. Stop and go to the train station.
5 mile drive in the PM- 15 min. Stop and go.
Weekend drives are a little farther.
[Linked Image from i837.photobucket.com]
Re: 2010 Traverse, Valvoline Maxlife 5W-30, 4,909 [Re: rbarrios] #5233772 10/08/19 11:05 AM
Dave Sherman Offline
FYI, even if you do maintain the oil level you may still lose the chains. I had a 2010 Traverse, the chains made it to about 170,000. Changed every 5,000 when I learned about the problematic timing chains, still managed to let go.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: 2010 Traverse, Valvoline Maxlife 5W-30, 4,909 [Re: rbarrios] #5233780 10/08/19 11:10 AM
R
rbarrios Offline OP
R
Did you ever have UOA and saw high Iron levels?
Re: 2010 Traverse, Valvoline Maxlife 5W-30, 4,909 [Re: rbarrios] #5234055 10/08/19 04:38 PM
B
buster Offline
B
With chain wear, ILSAC GF-6 will add the Sequence X which is a test for chain wear. Short-draining the oil will also help.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: 2010 Traverse, Valvoline Maxlife 5W-30, 4,909 [Re: buster] #5249941 10/25/19 04:03 PM
R
rbarrios Offline OP
R
any more info on this Sequence X?
