bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
16 registered members (GMguy84, Gokhan, Lufty, Char Baby, FirstNissan, FordCapriDriver, 1 invisible), 749 guests, and 40 spiders.
Topics306,116
Posts5,287,808
Members71,602
Motorcraft CV Joint Lube-Pak grease #5233591 10/08/19 07:05 AM
B
BEETLE Offline OP
B
Hello
I bought a Motorcraft CV Joint Boot Kit (TS-207) from Ebay. My question is, it contains 2 CV-Joint Lube-Paks One-Luber grease but it does not state which packs is Inner grease or Outer grease for CV Joint Boot application.
One grease pack is Black in color and the other grease pack is colored Brown.
Thanks in Advance
84 Isuzu P/up - Fram PH3950 - QS HM 10w-40
08 Ford Escape - Napa 31348 - Motorcraft 5w-20
98 Ninja 250 - Wix oil filter - RotellaT6 - 5w-40
Re: Motorcraft CV Joint Lube-Pak grease [Re: BEETLE] #5233616 10/08/19 07:35 AM
W
WyrTwister Offline
W
Does Motorcraft have a website that would have this information ?
Wyr
God bless
Re: Motorcraft CV Joint Lube-Pak grease [Re: BEETLE] #5233653 10/08/19 08:15 AM
T
tcp71 Offline
T
Not sure about this, but the black has more molybdenum and should be the outer cv, I think, due to the greater motion of the joint.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Motorcraft CV Joint Lube-Pak grease [Re: BEETLE] #5233777 10/08/19 11:07 AM
slacktide_bitog Offline
Is this for the Escape in your sig? smile
Ford actually sells OE NEW axles, so that's what I'd do
Ford and GM are the only companies I know of that actually sell all-NEW OEM CV axles! Everyone else only carries rebooted reground Cardone "reman" (cheaply done and with neoprene boots) mad
Honda, VW, and Subaru owners have access to Raxles. They make axles for *some* other cars but not all. Raxles uses all-NEW components and seem to actually be rebuilt properly.
Sorry for the rant, but given how lucky you are that you can actually get OE new axles, it's easier to just replace the whole thing smile
In regards to the grease colors, you can always ask the seller, a Ford dealer, or Ford directly. Does each packet have a separate part number on it?
Re: Motorcraft CV Joint Lube-Pak grease [Re: BEETLE] #5233863 10/08/19 12:30 PM
N
nthach Offline
N
Grease for tripod type CV joints is brown or tan and translucent. You don't want moly for the inner joints which are the tripod type. Those use needle bearings and moly won't let them roll as intended. The outer Repezza joint that uses balls and an cage uses the black grease.
Toyota does the same.
Re: Motorcraft CV Joint Lube-Pak grease [Re: BEETLE] #5242008 10/17/19 07:20 AM
B
BEETLE Offline OP
B
Hello
I finally installed both inner & outer cv boot into the axle. Tested and drove on the freeway, did not notice anything. Escape drove like a champ.
My worries is. Upon taking off the drive axle out of the vehicle, I had a struggle taking it out. I loosened the 32" nut and I hit it with a hammer, maybe 15 times. So, I consulted again my trusty...Chilton's Ford Escape Repair Manual and it stated the Lower Control Arm needs to be separated from the Steering Knuckle first. After I read this, I knew a made a BIG MISTAKE!!! So, I did what Chilton's stated on the repair manual and the cv axle came off after I tapped it with a hammer.
My concern is did I made an internal damage underneath my truck on the mistake I made? I jacked up the truck & the tire seems to be spinning straight.
Thanks
