Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
23 registered members (ctechbob, ChrisD46, 4WD, Darren_L, 330indy, 1 invisible), 721 guests, and 57 spiders.
Topics306,079
Posts5,286,969
Members71,596
Failed Honda Compliance Bushings after 42k miles #5233518 10/08/19 03:44 AM
The Critic Offline OP
Not sure what happened, though she does drive on a windy road during her commute.
I installed new front compliance bushings (LCA bushing) on the fiancée’s Accord at 97K. The car is currently at 139K and the passenger side bushing has a huge crack but the driver side is perfectly fine. ???
During the original installation, I tightened both bushings with the control arm raised to normal ride height (until the vehicle was no longer resting on the lift arms). But this time, I tightened the control arm bolts after lowering the car to the ground (and rolling it back and forth in neutral). Not sure if this will make a difference...
I ended up using the same Genuine Honda bushings again. Even without an alignment, ride quality has improved and the steering is a bit more precise. At least the bushings are relatively inexpensive ($25/ea) and fairly easy to replace.
Any ideas on what may have happened?
620688B9-6A08-47B7-BCEF-32259AEE8058.jpegCF1649D6-9E18-461E-A07B-1620B22EDF2F.jpeg307383FA-8A77-4FE3-AC33-E1FE3ADBB8CD.jpeg1737AE1E-21B8-469C-8713-BAC7595CA1B9.jpeg
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233522 10/08/19 03:56 AM
ctechbob Online Content
Online Content
*points to his signature*
Welcome to Honda life.
I did experiment with my 2003 when I did them a few years back and filled them with urethane before I installed them. Does it make a difference? Hard to say since I went from destroyed bushings to new ones, but I figured it was worth a shot.
You could always try out the Acura TL bushings. Same size and they were a heavier car. Are they different? Dunno, they are different part numbers and I'd like to think Honda made them a little stiffer to deal with the extra weight, but again, could just be a different number.
51394-SEP-A01 - Acura TL
Of all the Honda things I'm a fan of, I'm not a fan of this particular design.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233534 10/08/19 04:31 AM
dlundblad Offline
The control arm bushings on her Volvo are the same way.
Is there a poly version you can get?
What kind of bushing press is that?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233540 10/08/19 04:40 AM
Online Content
There's not really a poly bushing for these styles. There's a metal version, but its $$$ and I've got to imagine it will be fairly harsh, noisy, and probably still not last forever.
It looks like he's using either the official Honda Bushing tool or something similar.
I use a combination of ball joint pess parts when I do mine, plus a hollowed out and shaved down old bushing.
Trans-Idemitsu H+
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233544 10/08/19 04:57 AM
Silverado12 Offline
Any chance oil got on them? They will deteriorate if oil gets on them.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233559 10/08/19 05:48 AM
carviewsonic Offline
What are the symptoms when they are shot? Just wondering if that's something in my 2007 2.4 Accord's future?
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233571 10/08/19 06:35 AM
T
Trav Offline
T
Typically this type of bushing fails when the suspension is unloaded eg when jacking or putting it on a lift, this has plagued some GM vehicles for years.
The old bushings cant take the extra stress of being twisted to their maximum. Some fail right after jacking or lifting or shortly after, I have seen them fail on the lift. Do both sides.
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233617 10/08/19 07:36 AM
supton Offline
I've noticed that they seem to really flex when I lift my wife's car, but I don't see cracking (yet).
I wouldn't think an alignment would be required after this job, but, I'll ask anyhow--is it needed?
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233663 10/08/19 08:24 AM
A
amblerman Offline
A
This bushing seems to be a particularly bad design. I replaced mine (whole arm actually) about 50K ago and like yours, I just discovered the new ones are cracking.
I too also had jacked the arm up to a neutral position before tightening.
This issue seems to plague this generation of Honda accords. Next time I'll just be pressing in new bushing. I have been surprised at how much empty space is in that bushing. It doesn't seem surprising to me that the small web of rubber cracks. Given the size of the bushing I would have expected more rubber and less space.
The inner part of the bushing seems to be connected to outer bushing by maybe 55% of the contact area?Just seems odd.
BTW. .it looks like you have a nice workshop. Is that your personal space?
-A
Re: Failed Honda Compliance Bushings after 42k miles [Re: Trav] #5233693 10/08/19 09:07 AM
N
NoNameJoe Offline
N
I can see this happening because whenever I jack up the front and take the wheels off, yeesh the compliance bushings look like they're screaming for help with the amount of twisting they're doing LOL. This also makes any minor cracks really show, cracks you otherwise wouldn't see when they're not twisted (like if you were on the ground just looking up, the cracks would be completely invisible). One can probably assume that if they make cracks show by spreading them apart, they can probably make the cracks worse.
As for replacing the bushings, I remember the service manual saying you can only replace them once at most due to the interference fit of the bushings into the LCA...
2015 Civic LX Coupe
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233847 10/08/19 12:19 PM
1
1978elcamino Offline
1
I use to have a chevy cobalt, replaced the same bushings with the moog problem solver solid bushings @65.00 each. Pricey but they lasted much longer than the oem's, still solid when I sold it and dident notice any difference in noise.
Re: Failed Honda Compliance Bushings after 42k miles [Re: NoNameJoe] #5233864 10/08/19 12:31 PM
A
amblerman Offline
A
Interesting. I wonder if they are saying this because each replacement alters the hole for the bushing slightly and eventually it will fit loosely??
Re: Failed Honda Compliance Bushings after 42k miles [Re: amblerman] #5233876 10/08/19 12:43 PM
N
nthach Offline
N
More worried about the stress of pushing out the old pushing. That LCA looks like a forged aluminum part and not a stamped steel one which I can see elongating. What if you pressed in the new bushing after having it in a freezer for an hour to get the shell to ever so slightly contract which means less force needed to press in the new one?
I've done a similar job on an old Lexus but with aftermarket poly bushings. I had to hack the new bushings just to get them to work.
Re: Failed Honda Compliance Bushings after 42k miles [Re: nthach] #5233892 10/08/19 01:04 PM
A
amblerman Offline
A
It's definitely steel. I have a spare one in basement and I just checked it with a magnet.
Re: Failed Honda Compliance Bushings after 42k miles [Re: The Critic] #5233922 10/08/19 01:49 PM
M
mclasser Offline
M
Rubber parts seem to be a weakness on Hondas. My Pilot had it's compliance bushings done under extended warranty. They were cracked and leaking fluid at only 60k miles.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
