How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
83 registered members (ARCOgraphite, anthonym6, aquariuscsm, amh, ArrestMeRedZ, AndyB, 8 invisible), 1,890 guests, and 36 spiders.
Topics306,111
Posts5,286,761
Members71,588
Reccomend gear oil please #5233493 10/08/19 12:51 AM
T
TheProdigy001 Offline OP
T
Hello
I have a 2006 Chevy tahoe 5.3l 4x4 with the Eaton g80 differential.
Can anyone recommend me a good non ls gear oil. Every oil the parts store has says ls.
Thank you
Re: Reccomend gear oil please [Re: TheProdigy001] #5233497 10/08/19 01:23 AM
4WD Offline
There is an active thread on this and it comes up every few months … Delvac 1 from Summit Racing is what I use in my G80's
Re: Reccomend gear oil please [Re: TheProdigy001] #5233542 10/08/19 04:50 AM
Z
ZZman Offline
Z
I saw many references to people using, Amsoil, Royal Purple and M1 gear lubes with no issues.
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
Re: Reccomend gear oil please [Re: TheProdigy001] #5233604 10/08/19 07:21 AM
M
MaximaGuy Offline
M
Amsoil SVG
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Reccomend gear oil please [Re: MaximaGuy] #5233646 10/08/19 08:07 AM
Rat407 Offline
Originally Posted by MaximaGuy
Amsoil SVG
This in the new squeeze pack. Makes it an easy mess free job.
2002 Silverado 5.3 5w-20 AMSOIL
Re: Reccomend gear oil please [Re: TheProdigy001] #5233810 10/08/19 11:31 AM
T
totegoat Offline
T
The G80 uses any 75W90 oil with no additives. It doesn't know the difference from Walmart's oil or a designer oil. Spend as much or little as you want.
Re: Reccomend gear oil please [Re: TheProdigy001] #5241768 10/16/19 08:33 PM
T
T
I changed my gear oil about a week ago and I used supertech 75w90 full synthetic gear oil. The rubbing/vibration feeling on turns from a stop was gone very briefly but slowly came back when my wife drove to work. Has anyone else experienced this when using cheaper gear oil? Should I add the limited slip additive or change to a better gear oil
Re: Reccomend gear oil please [Re: TheProdigy001] #5241959 10/17/19 05:42 AM
K
ka9mnx Offline
K
First you asked for a non LS additive gear oil and now your asking if you should add it. I'm confused. ST is not a cheap gear oil and does have an LS additive.
To answer your question, no. I have ST syn 75w-140 in all my vehicles and I like it better than the M1 75w-90 it replaced. Only one of my vehicles (F150) has limited slip.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Reccomend gear oil please [Re: TheProdigy001] #5242309 10/17/19 12:16 PM
N
nthach Offline
N
Add an ounce of LS additive, drive the truck in a few figure-8s. If the noise is still there, add another ounce. ST oil is fine.
GM normally doesn't call for an LS additive in the G80 locker. It can't hurt though.
Re: Reccomend gear oil please [Re: ka9mnx] #5243842 10/19/19 04:07 AM
T
T
I only asked because after I changed fluid it still makes the sound when turning from a stop.
Also my rear differential was rebuilt and I dont know what or how they rebuilt it. I look online and see pics of eaton g80 locker and mine looks different. My differential has springs when you open and look at it. The g80 locker seems more mechanical. Any pic of a 06 g80 locker?
Re: Reccomend gear oil please [Re: totegoat] #5243848 10/19/19 04:33 AM
4WD Offline
Only the G80 is part of the rear end …
So, if AAM built it … they will recommend the lubricant to the vehicle’s Engineering team
That builder will recommend a synthetic knowing owners often neglect the rear end.
For the small amount more -vs- the hassle to change it … I’m going to be using something with pedigree
Re: Reccomend gear oil please [Re: TheProdigy001] #5243873 10/19/19 05:56 AM
U
userfriendly Offline
U
Am I the only one that uses 80W140 in G80s? Chevron makes a good one, good to -30F.
Re: Reccomend gear oil please [Re: userfriendly] #5244846 10/20/19 10:49 AM
Y
Y_K Offline
Y
I use it in other vehicles. It is closer to old spec straight 90. Excellent oil
“This disease making us more cruel to one another than if we are doggs.” -- Samuel Pepys 1666
