1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
78 registered members (ArrestMeRedZ, ARB1977, amblerman, 4WD, 94astro, 40w8, 3 invisible), 1,452 guests, and 68 spiders.
Topics306,081
Posts5,287,043
Members71,596
Another Subaru OEM 15208AA12A C&P 3900kms 2010 STI #5233451 10/07/19 10:25 PM
M
mcwilly Offline OP
M
Kind of getting boring, I've posted one of these 3 years running at my annual oil change. Low kms and nothing to report. Out came Mobil1 0w40 Euro and in went Castrol 0w40 Euro with another Subaru filter. Now that I have used up all my Subaru filters I may try a XG7317 next time. I will send the oil away later this week for Blackstone analysis, this will be the third analysis on this car as well currently at 77441 kms.
Everything works great and has great numbers except uncharacteristically high iron ppm, with no known cause at this time.
I had used approxiamtely 5oz of Hyperlube Zinc replacement with this sample, and I used the remainder of the bottle with the new fill. This at the recommendation of molakule and others.
20191007_163910.jpg20191007_164358.jpg20191007_164401.jpg20191007_164420.jpg20191007_164426.jpg20191007_164253.jpg20191007_164341.jpg20191007_155940.jpg
2020 Kia Telluride 2,000km
2010 Subaru STi 79,000km
2007 Buick Rendezvous 110,000km
2001 Toyota Echo 272,000km
Re: Another Subaru OEM 15208AA12A C&P 3900kms 2010 STI [Re: mcwilly] #5233452 10/07/19 10:27 PM
M
mcwilly Offline OP
M
First time running a magnetic drain plug too, theres the iron...
[Linked Image]
[Linked Image]
Re: Another Subaru OEM 15208AA12A C&P 3900kms 2010 STI [Re: mcwilly] #5233469 10/07/19 10:59 PM
Ded Mazai Offline
What gas are you using?
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Another Subaru OEM 15208AA12A C&P 3900kms 2010 STI [Re: mcwilly] #5233471 10/07/19 11:09 PM
slacktide_bitog Offline
Thank you for posting thumbsup
Fram's Subaru filter is PH9715
Wix is 57712, and they also offer an XP version 57712xP
If you want something longer, Wix has the 57055 (also available in both regular and XP)
Re: Another Subaru OEM 15208AA12A C&P 3900kms 2010 STI [Re: mcwilly] #5233473 10/07/19 11:13 PM
M
mcwilly Offline OP
M
Petro Canada Ultra 94.
Sometime in the new year I am planning on having a flex fuel conversion kit installed and hope to run E85 in the summer the Ultra 94 in the winter.
Currently running some Cobb bolt ons with an off the shelf map. The flex fuel kit includes all injectors, pump, rails, sensor, etc. and will require a custom tune. I'm also going to have the shop install an air/oil separator, although it has never shown any noticeable oil usage.
Re: Another Subaru OEM 15208AA12A C&P 3900kms 2010 STI [Re: mcwilly] #5233636 10/08/19 07:56 AM
A
ARCOgraphite Offline
A
I would look for something 2x the size of that "fuel filter".
Are you space limited with the bottom mount filter and EJ exhaust?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Another Subaru OEM 15208AA12A C&P 3900kms 2010 STI [Re: mcwilly] #5233650 10/08/19 08:11 AM
SubieRubyRoo Offline
I used to use 3593A and 7317 equivalents, I've since just switched to using the NAPA Gold 7055 on everything Subaru. It fits all of them, is much bigger than the 7712 size, and has a 27# bypass. It also has the finest listed nominal rating of the NAPA Subaru sizes, at 15 microns. When you throw in the fact that it's $3.77 on the Farm & Fleet sale, it's a no-brainer. All of the C&Ps here on the site look perfect to boot.
De omnibus dubitandum.
