Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
77 registered members (ABN_CBT_ENGR, aba4430, andyd, AdditiveOCD, 1foxracing, 2003f7, 8 invisible), 1,752 guests, and 35 spiders.
Topics306,112
Posts5,286,717
Members71,588
Who makes Sam's Club 80W-90 Gear Oil #5233415 10/07/19 09:29 PM
Spddm0n Offline OP
Does anyone know who makes the Sam's Club gear oils? I couldn't find any good images of labels on the 5 gallon bucket online.
[Linked Image]
Re: Who makes Sam's Club 80W-90 Gear Oil [Re: Spddm0n] #5233647 10/08/19 08:07 AM
A
ARCOgraphite Online Content
Online Content
A
WM gets a lot lube products from WPp up north here. WPp stuff has worked better for me than Mobil HD80W90 - which really doesnt belong in a modern car.
Does it really matter who blended this stuff ? as it is ancient technology made with low grade, high volatility napthenic oil.
I looked quickly for a SDS but didnt find it online quickly.
Where is it going? general 3rd member lube in a garage grease pit?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Who makes Sam's Club 80W-90 Gear Oil [Re: Spddm0n] #5233720 10/08/19 10:08 AM
H
hallstevenson Offline
H
If you search Sam's SDS listing, they have a generic entry for "Sam's Club 80W90 gear oil" but no way to confirm that it's this same product. If it is though, it's produced by Shell Oil.
Re: Who makes Sam's Club 80W-90 Gear Oil [Re: ARCOgraphite] #5233737 10/08/19 10:41 AM
Spddm0n Offline OP
I was wondering who made it so I could track down the product data sheet. I couldn't find one. WPP also doesn't seem to post their sheets anymore either. They have a SDS portal on the website, but it's wonky at best, and I'm not looking for safety data. I was looking for kinematic viscosity data.
Good questions? That is precisely the issue. I need a 80W-90 for front and rear DIFFs. The rear DIFFs all have LSD. Normally, I wouldn't buy such an oil, regardless of the application being used for, but only because I like to stick with what I know works. Lately, the market has changed and I can't get conventional oils with LSD additive and I'll have to add the additives to whichever conventional oil I choose. I wanted to make sure the viscosity isn't way out of range from the spec I like to use (Valvoline High Performance Gear Oil 80W-90 Limited Slip). Having said that, I don't even know where to begin evaluating whether an oil is made from a low grade or from high volatility napthenic oil. How can you determine the "grade" of oil it was made from?
Re: Who makes Sam's Club 80W-90 Gear Oil [Re: Spddm0n] #5234679 10/09/19 09:15 AM
A
Online Content
A
Most conventional gear oils are made from Napthenic oil. The high volatility isn't a concern for most med to light duty diffs as it would be in engine oil. This oil choice gives you the improved low temperature performance and Ep solvency.
Do you have a reason why you dont want to run the valvoline other than cost?
Unless you are mudding or boat launching with teh axles submerged, you shouldn't need to change diff fluids more than 60K miles at the most conservative.
Re: Who makes Sam's Club 80W-90 Gear Oil [Re: Spddm0n] #5235082 10/09/19 04:49 PM
B
BlakeB Offline
B
https://starfire1.com/pds/Starfire%20Conventional%20Gear%20Lubricants_PDS.pdf
I get this locally, costs me less than $3.50/quart after tax. I haven’t used it in anything limited slip, but I use it in lots of equipment with no issues.
