Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
106 registered members (97tbird, 53' Stude, 14Accent, 97K15004WD, 4WD, amh, 7 invisible), 2,846 guests, and 57 spiders.
Topics305,851
Posts5,281,408
Members71,525
Water hammer #5233380 10/07/19 08:42 PM
supton Offline OP
My new-to-me house has a wicked water hammer, but it’s worst on just the bathroom vanity. Would putting a hammer arrestor on the washing machine help? I’m thinking it’s too far away.
I have the water tank, then 15 or 20 feet to a tee. One side of the tee feeds the washer, dishwasher, kitchen sink, 15’ or so of line. The other side of the tee feeds the problem vanity and is likewise 15’ away. The washing machine, dishwasher etc do not seem to induce any hammer, but the one vanity on the other branch sure does.
I tried closing the valves on the vanity to reduce pressure, no change (that sink does have some wicked water flow!). I’ve added a bunch of hangers onto the copper pipes, but I don’t see any pipe movement when we make the hammer occur.
The problem vanity is copper all the way to the faucet. Maybe changing the line from copper to a standard hose would fix? Give it something that can flex a bit, that is.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Water hammer [Re: supton] #5233394 10/07/19 08:59 PM
Cujet Offline
Many homes have standpipes in the wall that are designed to trap air and eliminate water hammer. It's a simple solution that any plumber can make with just a "T" fitting and 2-3 feet of copper pipe with a cap at the top.
Over time, these can fill with water and the water hammer starts.
If your house has these primitive water hammer devices, you can evacuate all the water from your homes plumbing using a good shop vac. This will generally allow air into those pipes and solve the problem for a time. Or inject shop air while running water through the valve in question. Either will get air into the primitive hammer arrester.
Or simply install a modern water hammer arrester on or near the valve in question.
[Linked Image from structuretech1.com]
[Linked Image from robertsessaplumbing.com]
[Linked Image from images.homedepot-static.com]
Re: Water hammer [Re: supton] #5233420 10/07/19 09:37 PM
Chris142 Offline
So that's what those pipes in my wall are for! I never knew but I did wonder.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Water hammer [Re: supton] #5233481 10/07/19 11:44 PM
A
A_Spruce Online Content
Online Content
A
Yes, the 12" stub of pipe above where the angle stops are located are there for water hammer. Yes, over time they can become water logged, the cure is to turn off the water to the house and open the highest and the lowest valves in the house to drain the system down, thus restoring air into the hammer arrestors.
Interesting thing, I just did a major bath remodel and the plumber deleted the water hammer arrestors, said they weren't needed anymore. I'm not sold on that notion, but it could be that municipal systems are better at regulating pressure to the house so that hammer isn't as big a problem anymore. I don't know, but, personally, I'd rather have them and not need them than to be without and have issues.
I think that there are arrestors that can be installed between the angle stop and the fixture. Skip the big box and go straight to a plumbing supplier, they would have it if it exists.
'03 Suburban
Re: Water hammer [Re: supton] #5233516 10/08/19 03:30 AM
B
Bailes1992 Offline
B
I've never seen that done in the UK! Simple but bizarre fix.
It could be because we are better at maintaining/controlling water pressure over here, but generally we make sure all pipework is securely fixed and water hammer isn't an issue over here.
19 Volvo V40 D3 - 19 Jeep Renegade eTorq - 03 Ford Mondeo 3.0 V6 - 96 LR Defender 90 300TDi
Castrol Edge 5w30 LL
Valvoline Maxlife ATF
Fuchs Sintofluid 75w80
Fuchs Sintopoid 75w90
Re: Water hammer [Re: supton] #5233566 10/08/19 06:12 AM
F
Fawteen Offline
F
The simple way to stop the water shock is to close the vanity valves slower. There are a couple variables, but the real key is to slow the velocity of the water and not suddenly stop it, thus reducing the shock when a valve is suddenly closed.
You can always put an arrestor on the vanity under the sink.
The "municipal system" has nothing to do with it. Anytime water is under pressure and there's a sudden change in velocity, shock can happen. In a correctly designed system in the house it's not an issue-most hand valves don't slam closed fast enough to induce noticeable shock. But some washing machines and dishwashers still have valves that slam closed and cause a shock. Newer piping systems are also more resistant to transmitting the sound of the shock, whereas copper and old galvanized can make a lot more noise if not designed well.
Then the UK has somehow managed to get around the physics of how liquids work inside a pipe. Is your water over there somehow compressible? Or did you manage to over come wave celerity inside a pipe?
Re: Water hammer [Re: supton] #5233610 10/08/19 07:27 AM
supton Offline OP
I've looked and don't see any standpipes, but the pipes for the showers and washer do have plumbing that I can't see inside of the wall (house is a ranch so vast majority of the plumbing is visible). I've seen the tees with the hammer arrestor but those are of course more work to install than one on the washer (see here). Although this morning I now see this which looks like it could be added under the vanity easily enough; I hadn't seen that before (just the ones with sharkbite tees and I have not worked up the courage yet to cut into water lines just yet!).
Re: Water hammer [Re: supton] #5233985 10/08/19 03:16 PM
bdcardinal Offline
To be honest, I have never heard of water hammer outside of commercials on ARCA races for Sioux Chief arrestors and now here.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Water hammer [Re: supton] #5233996 10/08/19 03:26 PM
J
JTK Online Content
Online Content
J
It's odd that faucet taps induce the noise, where solenoid actuated valves on your appliances do not. It's typically the solenoid valves that do it because they snap full open and full closed so quickly. I'm thinking it's the specific plumbing run associated with the areas in question.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
