Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Jcvjr, Haywood, ToOliwer, AbbeyRoad, RPF
71587 Registered Users
65 registered members (alarmguy, aquariuscsm, Astro_Guy, Best F100, Alain2, 8 invisible), 1,507 guests, and 44 spiders.
Topics306,110
Posts5,286,695
Members71,587
Is my battery toast? #5233378 10/07/19 08:40 PM
I
irv Offline OP
I
Recently removed my Interstate deep cycle battery from my boat and noticed the water level low so I added the proper amount and put the battery on charge with a Battery Tender JR.
After a approx 10 hr charge, I checked the battery and it barely ready 5 volts. I then put my regular car/auto battery charger on it and switched it to 10 amps and also left it for approx 10 hrs but ended up with the same result.
I assume this battery is toast? This battery is likely 4-5 yrs old and was supposedly maintained by my marina where I purchased the boat. Judging by the low water level, I'd say they didn't even look at it before storage?
I never fished at all this year and for a few years prior to that so the only draw on it would have been my radio occasionally as I have a separate cranking battery.
Assuming I will have to purchase another battery, should I stick with an Interstate deep cycle or are there now better batteries on the market? I know this isn't any fault of Interstate batteries so I am not blaming the obvious neglect on them.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Is my battery toast? [Re: irv] #5233384 10/07/19 08:49 PM
B
Bluestream Offline
B
Keep it on a good charger, and it may come back. 24 hrs, and not on an electronic charger. I prefer East Penn batteries to the Mexican made interstate any day.
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: Is my battery toast? [Re: irv] #5233385 10/07/19 08:49 PM
Z
ZeeOSix Offline
Z
Yep ... toast. Time for a new battery.
Re: Is my battery toast? [Re: irv] #5233388 10/07/19 08:51 PM
Chris142 Offline
If you could see the top of the plates it's done.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Is my battery toast? [Re: Chris142] #5233398 10/07/19 09:05 PM
I
irv Offline OP
I
I could see the top of the plates on I believe 2 holes? When I seen that I also assumed it was toast but thought I'd try just the same.
I have never heard of East Penn batteries, Bluestream, but I'll look into them and see if I can get them up here?
Thanks guys. cheers
Re: Is my battery toast? [Re: irv] #5233448 10/07/19 10:15 PM
R
rubberchicken Offline
R
East Penn makes Deka, West Marine flooded and AGM batteries, Duracell and many more private brands that I cannot count. They are one of the largest battery manufacturers in the US, alongside Johnson Controls and GS Yuasa. I have had very good experience with Deka batteries.
Re: Is my battery toast? [Re: ZeeOSix] #5233453 10/07/19 10:28 PM
B
bbhero Offline
B
Burnt toast at that LOL
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Is my battery toast? [Re: irv] #5233490 10/08/19 12:36 AM
W
wrcsixeight Offline
W
Same pathetic voltage after attempting to charge is more an indication the chargers did not even recognize being attached to a 12v battery.
Parallel bad battery with a known 12.v+ good battery. Put 10 amp charger on good battery overnight or longer.
Highy
Doubt its voltage will read the same as before
But dragging a battery to such a low voltage slowly is batterycide. It.is likely toast.
A marine battery can be cycled..so can a starting battery. A true deep cycle.battery has very different constructed internals than either and would likely struggle to start the engine compared to marine or starting. A flooded marine battery is a starting battery with slightly thicker plates and threaded studs in addition to the posts, and a lot less warranty
Batteries do not go low on water from chronic undercharging. But from Too much time at too high a voltage for the battery temperature.
They always perform worseretaining voltage under load) after being watered as the acid is weaker.
A maintainer wil not be able to fully charge a depleted battery, it does not have enough amperage to ever get battery termianl voltage high enough.
Re: Is my battery toast? [Re: irv] #5233491 10/08/19 12:39 AM
W
wrcsixeight Offline
W
Highy
Re: Is my battery toast? [Re: irv] #5233539 10/08/19 04:39 AM
N
neil57 Offline
N
Costco batteries seem to be ok, ours are not interstate. Can’t beat the price. East Penn makes the Energizer line for Costco.
09 GMC 2500HD Duramax/Allison EFI live
2018 Chevy Cruz
11 Ford Escape
Be realistic,don't be fooled by delusions of adequacy
Re: Is my battery toast? [Re: irv] #5233708 10/08/19 09:45 AM
J
JMJNet Offline
J
Did you do a load test on the battery? It is easy to do with the right tool or bring it to a part store including WM with auto center.
  • 2017 Toyota Sienna
Re: Is my battery toast? [Re: irv] #5235064 10/09/19 04:25 PM
I
irv Offline OP
I
I'll likely purchase a Costco battery this coming spring. I tried re-charging my battery a couple times now but the voltage stays the same so it is toast.
I pulled the other cranking battery today when I finally stored my boat and noticed the water level was down in it as well. It was above the plates on all 6 holes so I added enough dehumidifier water to bring it back up to the proper height.
After I added the water, I checked the voltage and it was reading 12.56. Will this charge go down because I added the water or will it maintain that?
I know very little, obviously, about batteries but I would assume, since I added water, it will need a bit of a charge?
If so, is a Battery Tender JR OK to use in this situation? I have both, like I mentioned, but I was thinking about using the BT JR just to top up the charge before winter storage?
While I'm at it, will a BT JR or the like do any harm if the/a battery is already fully charged?
Thanks for the replies/info/tips so far. cheers
