Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
25 registered members (blufeb95, ctechbob, Crusher, bfleeman, ArrestMeRedZ, 3 invisible), 917 guests, and 28 spiders.
Topics306,228
Posts5,288,613
Members71,608
Mobil delvac extreme. #5233342 10/07/19 07:56 PM
R
Rglossip Offline OP
R
Recently went searching for a 10w30 full synthetic for my Kubota l3560 tractor. I had a hard time finding a full synthetic in this viscosity.I found Mobil delvac extreme online in a full synthetic. Found a distributer in Joplin who carried it. When it came in the mail it said semi synthetic. I called the distributer about it and they contacted Mobil. Mobil reclassified it as a full synthetic and has not changed the bottles yet. Mobil confirmed it to me personally. I thoughts this was very odd. Has anyone seen this before?
Re: Mobil delvac extreme. [Re: Rglossip] #5233458 10/07/19 10:37 PM
Z
zrxkawboy Offline
Z
No, haven't seen it personally, but it seems believable (product upgraded but use up all the old bottles). I'd take Mobil's word on it.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Mobil delvac extreme. [Re: Rglossip] #5233466 10/07/19 10:55 PM
4WD Offline
Mobil did several plant upgrades to produce GII+ … so it likely has a some amount of GIII to enhance that a bit.
Bet it's a solid HDEO - has a good list of builder approvals and specs
Delvac 1 line is where they typically add some PAO.
Re: Mobil delvac extreme. [Re: Rglossip] #5233512 10/08/19 02:58 AM
M
mattwithcats Offline
M
Try Shell Rotella T6 in 5W-40 or its hard to find little brother, 0W-40.
Advanced Auto has the 0W-40 on its web site...
That should be an HH164-32430 oil filter.
You can use a Fram PH8A or equivalent, same base, twice as long...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Mobil delvac extreme. [Re: mattwithcats] #5233514 10/08/19 03:20 AM
4WD Offline
Yeah … golden nectar of BITOG with a NOACK that’s beat by Delo and Delvac conventional at $12/jug
Re: Mobil delvac extreme. [Re: Rglossip] #5233545 10/08/19 05:02 AM
Slick17601 Offline
Run it till she blows!
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Mobil delvac extreme. [Re: mattwithcats] #5233695 10/08/19 09:10 AM
R
Rglossip Offline OP
R
I really wanted to run the t6 5w40 but Kubota only recommends 10w30 for winter and I was not 100 percent sure that 5w would be safe to use. They also informed me it could void my warranty if I came up with a warranty issue by using a non approved viscosity.
Re: Mobil delvac extreme. [Re: 4WD] #5233697 10/08/19 09:11 AM
R
Rglossip Offline OP
R
Sorry I do not understand the lingo you are using.
Re: Mobil delvac extreme. [Re: Rglossip] #5233829 10/08/19 11:55 AM
T
tundraotto Offline
T
You could choose from the following 10W-30 Heavy Duty Diesel oils:
Rotella T5 10W-30
Mobil Delvac Super 1300 10W-30
Mobil Delvac Extreme 10W-30
Chevron Delo XLE 10W-30
Valvoline Blue 10W-30
I just use 15W-40 year around since I keep my L2501 in the garage and it doesn't get that cold in Arkansas - I feel better with the 'thicker' oil since I run the tractor at higher rpms than most, and it gets very hot here.
Re: Mobil delvac extreme. [Re: tundraotto] #5233856 10/08/19 12:24 PM
R
Rglossip Offline OP
R
Ya I am only using it for cold weather.I will switch back to 15w40 in May.
Re: Mobil delvac extreme. [Re: tundraotto] #5233913 10/08/19 01:41 PM
R
Rglossip Offline OP
R
I am in Fulton Ks. It's been getting pretty cold with the polar vortex thing.I had the dealer install a engine block heater but I do not have a heated place to put the tractor.Its one of the reasons I bought it with a cab.
Re: Mobil delvac extreme. [Re: Rglossip] #5233943 10/08/19 02:25 PM
T
tundraotto Offline
T
15w-40 is fine in your climate - especially with a block heater. I would go as far as saying that I would rather have 15W40 and a block heater in the cold than any 5W-40 by itself. I am not a thinnie oil 'believer'.
Re: Mobil delvac extreme. [Re: tundraotto] #5233976 10/08/19 03:04 PM
K
kschachn Offline
K
Aren't they both 40-grade oils?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Mobil delvac extreme. [Re: tundraotto] #5234007 10/08/19 03:38 PM
R
Rglossip Offline OP
R
Definitely going to switch to a summer weight.Kubota gives the thumbs up to 10w30 all year around but I need more info before I run it 10w30 in the summer.
Re: Mobil delvac extreme. [Re: kschachn] #5234034 10/08/19 04:17 PM
T
tundraotto Offline
T
They are both 40-grade at 100°C.....and the one that has a 5W winter grade has much more friction modifiers etc. due to the 35 point span in grade, compared to 25 point span on the 15W40 The heavier base oils enable reduced wear compared to the lighter base oil 5W - if all other things are equal. I could not care less if I achieve 3% fuel savings on my tractor - I DO however want the best protection I can get when I am running the diesel engine flat-out under high load in 110°F heat in the summer.
