maverickfhs
Thread starter
Originally Posted by Bonz
Is that Chevron gas e10 or 100% gas?
I ran TCW3 in my ZRX1200 for a number of years. Pulled the head to install pistons, and the backside of the intake valves were just thick with carbon deposit buildup. I will be honest and say that I am guilty of the "if a little is good a little more can't hurt" philosophy and I'm sure I had too much going through it and it accumulated.
After cleaning everything up and running it for two years with the new pistons, I can look at the back of the intake valves when I have the carbs off and they are clean. I put one ounce in about every other tank, 5 gallon tank.
So 1 ounce every other tank, means 1 ounce per 5 gallon of tank and then wait until the following tank refill?
