Millions O Miles. ~Same Oil~
Northern Va.
- I perform 7K TO 10K Service mile intervals, fresh oil filter half the duration.
- Only use Motorcraft oil filters.
I have only ever use led Mobil1 Extended Performance. 5W30 most times by chance. Motorcraft oil filter combined wit dat earl, is quality maintenance to your air pump or engine.
Not sure I understand a) the point here and b) what you're saying.. especially after the opening sentence.
I hope it's working for you?🤔
Originally Posted by SubieRubyRoo
What's the point of changing your filter halfway thru without changing the oil? Maybe you should just use a better filter.... Wonder if Mobil/Purolator has bots trolling BITOG again?
Anything is possible. The OP seems to be a drive by. Hasn't been back since.
I can understand what he is saying - - -
I just want to know how many miles are actually on his Lincoln LS
