How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
80 registered members (Alfred_B, 97prizm, 1978elcamino, AlienBug, 2015_PSD, 53' Stude, 7 invisible), 1,902 guests, and 44 spiders.
Topics306,113
Posts5,286,744
Members71,588
3rd brake light assembly #5232650 10/07/19 07:10 AM
R
Redright9 Offline OP
R
Hello,
I have a '03 GMC Sierra.. I replaced the third brake light assembly a little while ago with an LED unit. I like the assembly, but being aftermarket doesn't 100% fit the cab and lets some water inside. Does anyone know a proper fitting assembly that is LED? Is my best option buying a factory assembly and just running LED bulbs? Should I put some kind of sealer around what I have?
Thanks.
Re: 3rd brake light assembly [Re: Redright9] #5232656 10/07/19 07:20 AM
K
Kira Offline
K
Is this a problem you caused by coveting LED's?
Pretty vehicle? Install something that fits. Abandon the LED feature if fit and finish is the goal.
Rough vehicle? Seal it with clear silicone sealer.
FYI: Go to a GM parts source and see what a "correct" one costs.
Your vehicle had a bulb CHMSL which you removed, no? Did you toss out your original?
Re: 3rd brake light assembly [Re: Redright9] #5232688 10/07/19 08:07 AM
F
Fawteen Offline
F
What does the "LED unit" do that the original one doesn't? The simple solution would be to put the original back in place unless it's damaged-problem solved. If it's damaged then just find a used one somewhere-problem solved.
Re: 3rd brake light assembly [Re: Redright9] #5232692 10/07/19 08:15 AM
R
R
The old (factory one) was just old and faded. I live in the desert and the truck is old. So it was time to replace discolored lenses. I like the LED's because they are bright and gave the truck a "cleaner" look.
Re: 3rd brake light assembly [Re: Redright9] #5232811 10/07/19 10:39 AM
Dave9 Offline
Sure you could try a sealer, maybe make a gasket out of neoprene rubber or run a bead of caulking on it, let that mostly set up before installing it so it is not permanently stuck on... despite lofty claims, some LED lights don't last nearly as long as they're supposed to.
An LED bulb in the original housing probably won't work out well because they tend to be nowhere near as bright as the factory bulb for little marker size bulbs, but if you want to try one anyway, get red because a far larger % of light will then pass through the red brake light lens.
You could instead try reconditioning the old lens with some plastic polish, or even toothpaste with a lot of elbow grease.
Re: 3rd brake light assembly [Re: Redright9] #5232929 10/07/19 12:47 PM
Deontologist Offline
You can get a rather long and very high quality Hella third brake lamp assembly off Amazon for about 60 dollars. It probably won't leak, ever, and those have been designed with the proper standards in mind.
The advice above about being careful with LED bulbs is correct. Too often they won't light up a red lamp correctly, and you've ended up paying good money for a downgrade in visibility. What size bulb are you looking for? 921? 1157?
Re: 3rd brake light assembly [Re: Redright9] #5233182 10/07/19 05:08 PM
R
R
https://www.amazon.com/gp/product/B00O83N0WA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This is the unit I purchased...
It's plenty bright, just needs to seal better.
(within reason) not too worried about price, a $60 better unit that also seals is not out of the question...
Re: 3rd brake light assembly [Re: Redright9] #5233191 10/07/19 05:24 PM
If it needs to seal better, and it doesn't fit right, according to both your post and the numerous Amazon reviews, it's probably high time to look for another unit, perhaps one from a recognized manufacturer.
Re: 3rd brake light assembly [Re: Redright9] #5234571 10/09/19 07:35 AM
M
meep Offline
M
Me and clear caulk get along pretty good...
2018 F150
2015 crv (wifey!)
