4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
97 registered members (4WD, 53' Stude, 86cutlass307, 14Accent, 2K2AcuraTL, 2015_PSD, 13 invisible), 2,708 guests, and 45 spiders.
Topics305,847
Posts5,281,384
Members71,525
2017 GMC Terrain oil change...help #5232442 10/06/19 09:10 PM
G
gregk24 Offline OP
G
My parents purchased a 2017 GMC Terrain recently. I will be performing oil changes on it.
What I am needing to find out is, what size oil drain plug do these use, and does GM use a crush washer on these?
Since this is BITOG, I do plan on using an A/C Delco oil filter, and either Mobil1 or Pennzoil Platinum 5w30. The interval will be 5K miles or whenever the oil life monitor goes off. Whichever comes first.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 2017 GMC Terrain oil change...help [Re: gregk24] #5232460 10/06/19 09:26 PM
N
NothingNew Offline
N
Your parents have the 2.4L. Should be 15mm. It uses a washer, but not necessarily a crush washer.
Re: 2017 GMC Terrain oil change...help [Re: gregk24] #5232461 10/06/19 09:26 PM
Chris142 Offline
Every GM I have seen in the last 20+ years used a plug with a captured O-Ring. Usually a 15mm head on it. But that may have changed.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2017 GMC Terrain oil change...help [Re: gregk24] #5232463 10/06/19 09:27 PM
I
Imp4 Offline
I
Gold Plug claims an AP-02 application here for both the 2.4 and the 3.6.
M14 x 1.5 threads with a 17mm hex head.
OEM may differ in the hex.
Re: 2017 GMC Terrain oil change...help [Re: gregk24] #5232481 10/06/19 10:05 PM
slacktide_bitog Online Content
Online Content
If you have the 2.4, the best oil filters to use are Hengst, Mann, and Purflux.
Hengst is the OE supplier, and Purflux used to be the OE supplier. Purflux uses those chevron pleats which may help against buckling
Hengst E630H is the actual OE oil filter (ACDelco PF457G/)
The PF457G does NOT include a new O-ring! crzy
If you want one, there is the PF457GO
(if you ever need a new cap, the PF458G includes the filter, cap, and O-ring)
The Hengst "aftermarket" filter in the Hengst box does include an O-ring smile
One O-ring, ONE OCI LOL
The Purflux part number is L264A (and yes, it includes an O-ring)
Re: 2017 GMC Terrain oil change...help [Re: gregk24] #5232489 10/06/19 10:18 PM
dishdude Offline
The drain plug has a built in o-ring that will last the life of the vehicle.
The o-ring on the filter cap is NOT supposed to be replaced, that's why the AC Delco filter does not include one. For some reason the aftermarket filters include one that is a much lesser quality than OEM.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: 2017 GMC Terrain oil change...help [Re: slacktide_bitog] #5232502 10/06/19 10:43 PM
G
gregk24 Offline OP
G
I found that PF458G on Amazon for less than $8.00 shipped. Sounds like a deal.
61,xxx miles
54,xxx miles
Re: 2017 GMC Terrain oil change...help [Re: gregk24] #5232529 10/06/19 11:38 PM
T
tiger862 Offline
T
Oil the oil filter oring then install oil filter in housing making sure it is fully seated then oil cap oring install cap. Easiest oil change you will do. I believe the cap used a 1 1/4 shallow socket.
Tiger862
2018 Grand Caravan
Re: 2017 GMC Terrain oil change...help [Re: dishdude] #5232658 10/07/19 07:28 AM
Dave Sherman Offline
Interesting, didn't know that. The nearby Autozone never seems to have the AC Delco in stock. I've used the STP filter that comes with an o-ring and replaced it. Never had a leak, though.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: 2017 GMC Terrain oil change...help [Re: dishdude] #5232844 10/07/19 11:24 AM
G
GMBoy Offline
G
That is correct. If you see a blue or orange O-ring - reuse it. The black one that comes with most filters is not as durable and requires replacement at each change but they may last 2 OCI's. The OEM one is designed for many uses. I did, however, replace the one on my 08 CTS last year lol - cheap insurance for a well used O-ring!
Re: 2017 GMC Terrain oil change...help [Re: gregk24] #5233097 10/07/19 03:28 PM
M
Matt1980 Offline
M
I did the same thing when I started changing the oil on my 2011 Terrain. I didn't realize that the O ring was a life time ring that GMC does not want you to replace. I ended up ordering a new OEM on eBay a few years ago and have been using it ever since. The OEM part number is 12580255 if you want to order one on ebay. It only cost a few bucks.
