1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
68 registered members (4WD, amblerman, 40w8, 94astro, alarmguy, 86cutlass307, 5 invisible), 1,343 guests, and 57 spiders.
Topics306,081
Posts5,287,032
Members71,596
Idiot put 4qts in 250cc Ninja #5232341 10/06/19 07:32 PM
A
ammolab Offline OP
A
Well see....the first 2 quarts went RIGHT THROUGH! Yep, no drain plug!
Since the bike “rejected” that SuperTech MC 10W-40 Synthetic....I put in Mobil 1 MC 10W-40.
Yep, I was the “idiot” and think I will just say it was the thorough oil pan flush I do every 22,000 miles.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232355 10/06/19 07:46 PM
ctechbob Offline
First bike I ever owned was one of those, back in 1994. Good little bike, rode the snot out of it for about 20,000 miles and bought a ZX6E the next year. Wish I still had that one. Very good all around bike. Not the fastest, but a good ride.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232358 10/06/19 07:48 PM
danez_yoda Offline
I've done that too. 5 quarts though. Nice flush if the engine. Oil pan was full of dirty oil that mixed with the good oil so I couldnt pour it back in. frown
lucky for me I had another 5 qt jug in the garage. Wont do that again for a long time at least.
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232379 10/06/19 08:08 PM
U
user52165 Offline
U
I am mostly bike illiterate. Is there a filter?
Re: Idiot put 4qts in 250cc Ninja [Re: user52165] #5232397 10/06/19 08:26 PM
A
ammolab Offline OP
A
Originally Posted by user52165
I am bike illiterate. Is there a filter?
There is a cartridge filter stock, but I replaced that unit with a machined adapter that allows the use of a spin on filter. The same filter as our Honda CR-V. I had the filter on but took a break and forgot to put that darned drain plug in when I returned to duty.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232404 10/06/19 08:31 PM
U
user52165 Offline
U
So this was not an intentional flush?
I thought your reference to idiot was in jest.
Re: Idiot put 4qts in 250cc Ninja [Re: user52165] #5232410 10/06/19 08:41 PM
A
ammolab Offline OP
A
Not at all intentionally done. 2 quarts right onto the vinyl mat under the machine to catch “drips”. BIG MESS!!!!
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232443 10/06/19 09:10 PM
ctechbob Offline
Don't feel bad. Been changing various oils for the last 25 years and the last trans oil change on the Acura I forgot to put the drain plug back in. Luckily the pan was still under it and I only dumped 1qt, but still, felt ultra-stupid.
Trans-Idemitsu H+
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232457 10/06/19 09:24 PM
U
user52165 Offline
U
Fumoto
Re: Idiot put 4qts in 250cc Ninja [Re: user52165] #5232539 10/07/19 12:10 AM
blupupher Offline
Fumoto
Still have to close it.
I did a 5 qt flush on my Santa Fe when I put on my drain valve. Just forgot to close it after I installed it. duh
I had just poured in the 6th qt of oil and stepped back and heard a weird sound, looked to see oil draining out of the new valve. Grabbed the empty jug and caught about 1 qt of the oil, but 5 qts had gone into the drain pan with the old oil.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232711 10/07/19 08:30 AM
A
ARCOgraphite Offline
A
I hate that word FUMOTO. Its a 1/4 turn globe valve.
Lots of U.S. companies make them.
Fumoto. Must have started with the garbage JDM crazies.
rant over.
As for no drain plug?
Just say no to mind altering substances.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Idiot put 4qts in 250cc Ninja [Re: ammolab] #5232919 10/07/19 12:35 PM
K
kmrcstintn Offline
K
did something similar on a diy oil change on a truck I owned back in 2004 (chevy silverado, 2wd, 4.3l v-6)...forgot to look at old filter coming off; seems the old gasket stuck to mounting adapter, put on new filter, completed oil change, and started it to check for leaks...stepped away for @ 1 minute; saw a big puddle of oil on ground below vehicle...shut off engine, cleaned mess, crawled under truck, and saw where oil leaked from; befuddled I checked tightness of filter...ok then I looked at old filter & saw no gasket! ugh...undid new filter, lost more good oil into drain pan, cleaned everything up, put new filter back on, and rode bicycle to nearest auto parts store to buy more oil...I musta looked frustrated & someone asked what happened; embarrassed I told the story, was told I wouldn't be the last person to do it, and we all chuckled; returned home and put in @ 1 3/4 qts...finished cleaning up after another leak test;
'18 Dodge Journey(2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
