Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
105 registered members (2015_PSD, aquariuscsm, another Todd, 4WD, ArrestMeRedZ, AandPDan, 12 invisible), 2,104 guests, and 47 spiders.
Topics306,137
Posts5,288,203
Members71,604
Change oil filter, but not oil due to rate of consumption? #5232169 10/06/19 04:03 PM
E
EchoThat300K Offline OP
E
My 2002 Toyota Echo has almost 300k miles on it. I use about a quart of high mileage synthetic blend per month/1000 miles. After 5 months and 5000 miles, I only have a quart and a half of the original oil in the car. I keep adding new, clean oil each month.
Can I just change the filter instead of changing the oil and filter every 5000 miles? Maybe take the complete oil and filter change out to 10k miles, or once a year?
300k miles is a long way to drive to be basically in the same place that you started.
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232190 10/06/19 04:31 PM
E
earlyre Offline
E
extended life filter changed yearly sounds like a plan to me...
Mine:
13 Ford C-MAX hybrid: Bulk Maxlife Full Syn 5w20,& Valvoline Jobber Filter
( I was Lazy and had a Groupon)
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232205 10/06/19 04:49 PM
F
fozzdesy2001 Offline
F
I'm in the same boat as you with my beater Subie but can't help myself so I do 2 changes a year including a new filter each time. Guaranteed tp have good oil as long as it's topped up. Cheapest I can find works for me.
2001 Subaru Forester S
Replaced with a 2006 Forester
2004 Subaru Forester XT
Death by deer. Replaced with 2003 Impreza Outback Sport (beater)
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232217 10/06/19 05:01 PM
R
Railrust Offline
R
Honestly I think that at 300,000 miles you can do whatever you want, and I have certainly heard of people doing it if their cars are using that much oil and their mileage is that high.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232221 10/06/19 05:04 PM
E
E
Thanks.
I appreciate the advice.
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232226 10/06/19 05:19 PM
danez_yoda Offline
My wifes toyota sienna has 100k and uses no oil, manufacturer recommends 10k mile oci anyway. i do 5k because thats when the oil light comes on but sometimes i feel guilty draining out oil that looks that good and skip with no issue.
10k on an oem toyota filter is a no brainer. many of the cheapie filters ([censored] abd supertech) Re claiming 10kmile life.
i cant bring myself to leave a half qt of dirty oil in the engine when changing it so i dont reuse filters but if you are continuously adding oil then ok. change it every 10kmiles. you might just get a clean catch pan and pour the drained oil back in since it will be fairly new and refreshed.
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232227 10/06/19 05:19 PM
JohnnyJohnson Online Content
Online Content
I would get a Fram Ultra or a Mobil 1 filter and leave it on there a year I'd dump the oil twice a year. Probably to with
something like Havoline Pro DS 5w-30 in the box for $19.97 and have two quarts of left over oil to add as needed.
2004 Corolla 140120
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232372 10/06/19 08:03 PM
P
paoester Offline
P
Filter once a year. Oil change every 2 years. That is a lot of addtives you are replacing.
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232381 10/06/19 08:09 PM
CR94 Offline
A little math will clearly answer this perennial question.
2011 Toyota Prius now at 110K
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232468 10/06/19 09:31 PM
J
JLTD Offline
J
Numerous threads on this over the years, backed up with some UOAs.
At that level of consumption, the consensus has been to change the filter at regular intervals and keep the oil level topped off. I'd grab a Fram Ultra and go 20,000 miles.
Another good use for the Havoline 6 quart box.
Lates.
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5232751 10/07/19 09:18 AM
F
Farnsworth Offline
F
Have a compression check and other tests to try and determine what's the cause. In the old days engines were overhauled. Myself I would keep changing the oil and filter at the 5k interval, at the time when it is a bit down. You don't live in the arctic, try 30 good quality detergent oil, won't hurt it to try. Add a can of stp if the 30 doesn't help enough, if they still make it. My 2cents
Re: Change oil filter, but not oil due to rate of consumption? [Re: EchoThat300K] #5235866 10/10/19 12:29 PM
DGXR Offline
I agree with the suggestions to get an extended life oil filter and change just the filter every 12-15k miles. And while you are adding enough fresh oil to justify no longer draining the crankcase, ever... you still want to pull the plug periodically (maybe every every 2-3 years?) to to drain any sediment from the bottom of the pan.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
