1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
75 registered members (ArrestMeRedZ, ARB1977, amblerman, 4WD, 94astro, 40w8, 4 invisible), 1,416 guests, and 75 spiders.
Topics306,081
Posts5,287,038
Members71,596
Hose Leak At Bib, Tried New Hose & Washer #5231891 10/06/19 10:53 AM
Dwight_Frye Offline OP
I just moved into a home in a mountain community. The home was built in 2018. The only hose bib on the front of the house is inside the finished garage, about 10 feet from the door opening. That seems rather ridiculous but that's where it is.
Not being one to take my car to a commercial car wash, and notwithstanding there are none within 25 miles anyway I wanted to wash my car myself. I attached my garden hose, turned on the water and it leaked like a sieve, squirting water all over the drywall by the bib and poured out on the garage floor. I changed the washer and made sure it was tight. Same problem.
OK, so I went to Lowes and bought a fairly expensive new hose. Made sure the washer was in place, hand tightened it and it too leaked like a sieve. Tried tightening it with a wrench. Still leaked like crazy.
This is unacceptable. Did I get a defective new hose or is there something wrong with the spigot and I need to have a plumber come out and pay $$$ just so I can wash my car ?
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231893 10/06/19 10:57 AM
W
Warstud Offline
W
Sounds like it's defective. For the time being...try some plumbers tape
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231900 10/06/19 11:05 AM
PimTac Offline
Sounds like a good opportunity to move that hose bibb to the exterior where it should be. Install a shutoff where the current hose bibb is located if your area freezes during the winter.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231905 10/06/19 11:09 AM
satyr64 Online Content
Online Content
Probably leaking from the hose Bib Anti-Siphon Valve. Just remove the valve if that your culprit.
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231930 10/06/19 11:32 AM
M
MasterSolenoid Offline
M
Could be leaking in several places.
Look closely to see exactly where.
This will dictate where to put your effort.
1) Packing Washer (around spindle) - Tighten Packing Nut alittle at a time OR replace with Teflon Rope
2) Stem Washer - Replace
3) Make sure you have a washer in your Hose end (I see you did).
With this being a 'new' house, I'd look at the Hose first.
I don't like the Washers that come with Hoses / I bought replacements that look like big rubber O-rings.
[Linked Image]
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231938 10/06/19 11:38 AM
F
Fawteen Offline
F
A good starting point is to pinpoint exactly where it's leaking from. If you don't do that then anything else is just guesswork.
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231952 10/06/19 11:48 AM
O
oldhp Offline
O
Cap off the faucet. Turn it on. I'll bet you find your leak, I don't think it's the hose.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231960 10/06/19 11:51 AM
O
oilpsi2high Offline
O
If it's not the hose, then it's likely leaking from the faucet itself - on the diagram above, from the packing washer.
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231968 10/06/19 12:11 PM
I checked the male threads on the spigot for damage and concentricity and it seems OK. The water is pouring out around the junction of the hose and the female connector fitting on it, not squirting around the handle and/or packing nut on the spigot. I think I have some of those big rubber O Ring type washers, I'll try that and if not try oldhp's suggestion of capping off the faucet and seeing if the issue is the spigot. At least it is not soldered to the pipe that sticks out of the wall, if the spigot is bad I can probably turn off the main water valve and replace it.
This is the hose I bought at Lowes:
https://www.lowes.com/pd/Teknor-Ape...ink-Free-Vinyl-Gray-Coiled-Hose/50328059
They claim "leak proof commercial couplings". Maybe not...
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231981 10/06/19 12:23 PM
W
Warstud Offline
W
If it leaked with the old hose and a brand new hose I would think the problem lies with the spigot. At some point is it hard to tighten the hose?
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: satyr64] #5231993 10/06/19 12:33 PM
N
Nukeman7 Offline
N
Satyr64 is probably correct. Yo don't need the anti-siphon valve unless the outlet end of the hose will be connected to something toxic like a herbicide/pesticide sprayer. Here is a Youtube video that show you how to replace it:
Hose Bib Anti-Siphon Valve Replacement
Re: Hose Leak At Bib, Tried New Hose & Washer [Re: Dwight_Frye] #5231999 10/06/19 12:43 PM
M
maxdustington Offline
M
https://www.youtube.com/watch?v=Gw7BSrWH1Ck
Probably not a defective hose if you tried a different hose. Built in 2018 and leaks like crazy? Is there any warranty or anything? Sounds like builder grade crap was installed and not tested.
You can try the repairs in the video, but there's a pretty good chance the valve is defective or there is some junk in there interfering with the valve sealing. I would disassemble, clean and replace the soft parts. It's not a big deal to replace it if you have the tools, but buying the tools might end up costing as much as calling a plumber.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Hose Leak At Bib, Fixed It [Re: maxdustington] #5234726 10/09/19 09:55 AM
I inspected the spigot and it does not have an anti-siphon contraption as part of the assembly. It is also not leaking around the valve stem. The problem is that the POS new hose has too much clearance between the female threaded coupling part and the flange fitting inside on the actual hose. I ended up using 2 of the red rubber hose washers to take up the slack in the fitting and then tightening it down by hand as hard as I could without resorting to a wrench. No more leaks.
Re: Hose Leak At Bib, Fixed It [Re: Dwight_Frye] #5234978 10/09/19 02:35 PM
Yah-Tah-Hey Offline
Check the male threads for damage.
Re: Hose Leak At Bib, Fixed It [Re: Dwight_Frye] #5235671 10/10/19 08:59 AM
A
andyd Offline
A
Whatever it takes. Some times it takes tape . In my low budget/ labor intensive world, one must make use of what's available. A hand tight seal is perfect. It has taken me decades to attain tight hose connections The tray on my mounted hose reel is loaded with washers and shut offs an 2 crummy sets of pliers. grin2
Thick oil is better grin2
