Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
49 registered members (BeerCan, bernardch, BigGeo, 2009Edge, Amkeer, Best F100, 4 invisible), 1,101 guests, and 49 spiders.
Topics306,279
Posts5,289,455
Members71,616
1995 VW Van possible synchro issue thoughts? #5231889 10/06/19 10:46 AM
R
ryan2022 Offline OP
R
Hi guys,
A good friend of mine has a mid nintees VW Van with the Audi 5 cyl and a manual transmission.
The van runs great, and the transmission shifts fine usually, although third gear has been giving him the odd issue.
Under a normal upshift into third it shifts fine....with a very slight crunch if he's hustling it, the issue is on the downshift.
When downshifting from 4th it will sometimes balk, or make a nasty crunch sound as if it was a bad synchro.
We both feel like a synchro issue is usually on the upshift.
Does anyone have this problem, or any thoughts?
Thanks,
Ryan
2011 Subaru Impreza Hatchback 5w30 Mobil 1
2015 Subaru Outback 2.5 Limited 0w20 Mobil 1 AFE
1995 Nishiki Navajo mountain bike....some kind of chain oil.
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5231897 10/06/19 11:03 AM
skyactiv Online Content
Online Content
Try a new gear oil. The synchro is probably worn out. Not worth fixing unless you can do it yourself and you really want to fix it. $$$$ to have a mechanic do it.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: 1995 VW Van possible synchro issue thoughts? [Re: skyactiv] #5231910 10/06/19 11:16 AM
R
ryan2022 Offline OP
R
He just changed the oil, from probably original fluid.
Are there any gl4 fluids that you guys would recommend?
Would royal purple synchromax be the correct weight?
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5231921 10/06/19 11:27 AM
Nick1994 Offline
Have him check all the shifter bushings.
Probably a different setup, but on my aunt's 70' Beetle it shifted pretty bad when she first bought it. The shifter bushings were toast, I replaced them and it's pretty darn good now.
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5231924 10/06/19 11:29 AM
W
wag123 Offline
W
Red Line MT-90 75W90 GL-4 Full Synthetic Gear Oil.
Downshifts are where bad/worn syncros really show themselves, this is where you can really hear the syncros spinning up the gearset.
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5231925 10/06/19 11:30 AM
Delta Offline
VW owners swear by Redline MT90. Do not use the Royal Purple as it's designed for manual transmissions that take automatic transmission fluid. It's a light viscosity.
However I don't think there's a magical fix to your friends transmission. I had the same issue in my old S10, 3rd gear syncro was pooched. I had to double clutch or rev match it most days, this will likely be what your friend will have to do unless he wants to go through an expensive rebuild.
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5231957 10/06/19 11:49 AM
O
oldhp Offline
O
Make sure you are getting full clutch disengagement too.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5232007 10/06/19 12:56 PM
Cdn17Sport6MT Offline
Molakule has a good treatise here on BITOG re MTL's; cannot put my hand on it just now. In it he gives a breakdown of various viscosity ranges. U should find out what the vw owners's manual recommends and go from there... generally lighter MTL within the same overall SAE viscosity range will give better synchro action at the expense of slightly lower gearface + rolling element bearing wear protection. But friction modifiers are also at play with synchro feel. Redline is one of the best out there for shift feel improvements - but a certain contingent of folk have seen evidence of additive drop-out / sludge formation - and the net fluid left giving no wear protection - with some Redline products. Hence they have seen heightened wear 😮.
Mazda6 GX (i.e.Sport), 6MT, '17
Moto Guzzi 850 T5 (Euro version), '85
Honda Civic Si (EX 2 dr in the 'States), A/T, '97
Toyota Camry CE, 5MT, '99
Toyota Corolla VE, 4AT, '99
VW (Type2) Kombi, 4MT, '79
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5232011 10/06/19 01:05 PM
If the manual says use GL-4 do NOT use GL-4/GL-5 "dual" rated or GL-5 ' cuz it'll (chemically) knacker the yellow- metal synchro's 😐
Re: 1995 VW Van possible synchro issue thoughts? [Re: Delta] #5232142 10/06/19 03:30 PM
T
Trav Offline
T
Unless they operate in cold weather then its the worst fluid in the world it just plain sucks. I run Pentosin MTF2 after horrible cold shifting with that Redline, it was money down the drain. IIRC it has been discontinued by Pentosin but RAVENOL MTF-2 75w80 works as well.
With MTF2 shifting in winter is the same as summer, no noise or weirdness even in 100f weather.
Re: 1995 VW Van possible synchro issue thoughts? [Re: ryan2022] #5233556 10/08/19 05:42 AM
another Todd Offline
Might have to start burping the throttle when down shifting to get a closer engine/gear selection match and take some of the load off the syncros.
2017 Ford Escape 2.0
2002 GMC Yukon
2008 Yamaha Rhino 700 FI
2010 Itasca Meridain/Freightliner Cummins 6.7 non DEF
Re: 1995 VW Van possible synchro issue thoughts? [Re: Nick1994] #5233893 10/08/19 01:05 PM
N
nthach Offline
N
The OP's friend has the Eurovan, the T4 which is a transverse FWD layout that's much simpler than the T1-T3 that's literally a little T-drive bus. It should be a cable-shift like the A2-A3 Jetta/Golf of that era.
Try a GL-4 manual transmission oil first before looking at a rebuild.
