Original thread: https://www.bobistheoilguy.com/foru...ith-new-tacoma-v6-manual-4x4#Post5166631
On paper, the 3.5L looks weak. Only 278 HP, and 265 ft-lbs at a rather high RPM. However, when hooked up to the manual gearbox, it became a surprisingly capable machine.
It still felt like an older truck, but in a good way. The 3.5 had more power in the lower RPMs than expected, and it handled a 4500 lb. boat and tandem axle trailer pretty easily, even in the mountains.
Unless you need (or want) the TRD Pro goodies, however, you can just get the TRD Off-Road. You'd still get the V6 and manual gearbox, locking rear diff, and 4WD. Suspension wise, you'd get Bilstein suspension (that's way cheaper to replace when it wears out) and a slightly shorter track versus the FOX shocks and wider stance.
More thoughts for those interested: https://chrisleoonline.com/2019-toyo...rd-pro-review/
