1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
97 registered members (2oldtommy, 77GrandPrix, Ag76, ammolab, 2015_PSD, 4WD, 5 invisible), 2,144 guests, and 35 spiders.
Topics306,140
Posts5,288,238
Members71,608
Page 1 of 3 1 2 3
283,500 miles CVT fluid 1st change #5231424 10/05/19 07:42 PM
B
bbhero Offline OP
B
Well it finally did happen... After 293k miles plus... I did a drain and refill on the ol Altima VQ CVT two door coupe....
Fluid was brown like motor oil with about 2 thousand miles on it.... I have heard others on here who have had the CVT fluid look jet black or like diesel oil... Which would be not good to see... My CVT fluid barely had any color to it until about 120k miles.
My driving pattern is very, very easy on it too... A whole lot of open highway driving which obviously helps keep the CVT temperature lower by a wide margin too.
I used Castrol Transmax CVT fluid that I got at AZ for a tad over $7 a qt... I plan on changing the fluid one more time in the next few weeks.
Guess I don't have to worry about the color of the fluid being red from Castrol because I am well, well out of warranty LOL
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231430 10/05/19 07:49 PM
sw99 Offline
Wow that great for a Nissan CVT... Really though that's great to hear. I have always been curious on the longevity of these relatively new CVTs. Thanks for posting the news.
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231431 10/05/19 07:49 PM
J
JC1 Offline
J
Wow, that's a long time to go on Transmission fluid. What color is the new CVT fluid?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 283,500 miles CVT fluid 1st change [Re: JC1] #5231442 10/05/19 08:02 PM
B
bbhero Offline OP
B
Well it was red Castrol Transmax CVT fluid... I drive around for about 40 miles. And when I checked it when I got home and it was a light brownish color.
The more drain and refills I do I bet the red color of the Castrol Transmax CVT fluid could be there.
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231446 10/05/19 08:04 PM
A
atikovi Offline
A
Are you the original owner? Nissan had a 120K extended warranty on the early CVTs so it may not be the original one.
Re: 283,500 miles CVT fluid 1st change [Re: atikovi] #5231460 10/05/19 08:14 PM
B
bbhero Offline OP
B
It had 39,990 miles on it when I got it.... Never had any CVT work at all. Original.
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231462 10/05/19 08:14 PM
J
JeffKeryk Offline
J
Any change in trans feel?
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231464 10/05/19 08:15 PM
1
14Accent Offline
1
Have you had the car since new? It doesn't surprise me much that the fluid was still good, if you do mostly highway driving. The only real wear in a CVT is the belt or chain as the ratios change. If you just sat in the tallest ratio on the highway all the time, the only other thing the fluid does is lubricate and cool the bearings. I suppose there may be some wear from the torque convertor clutch, but with your driving habits I would guess it just stays locked most of the time, so no wear there either.
Congrats on the high mileage, though! It doesn't say what year your Altima is, but I would guess it's between an '08 and '12. Either way, that's a LOT of miles! Good thing Nissan uses those NASA-inspired seats!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231476 10/05/19 08:26 PM
CR94 Offline
Does that CVT use a belt, or is it the other type Nissan used to use, with sorta hemispherical-shaped components that rolled against each other? (Sorry, I forget what they called that kind.)
2011 Toyota Prius now at 110K
Re: 283,500 miles CVT fluid 1st change [Re: JeffKeryk] #5231492 10/05/19 08:34 PM
B
bbhero Offline OP
B
Not a big difference really man... Though I will say it is quieter than it was at lower speeds of 45 mph or less... That was good to notice.
Hope you had a good day today...
I am sorry for being a bit cantankerous the other day.
In all actuality we were not all that far apart on that deal. I just did not handle that well at all.
Re: 283,500 miles CVT fluid 1st change [Re: 14Accent] #5231496 10/05/19 08:37 PM
B
bbhero Offline OP
B
Yeah I got her in Nov 2012... 2nd owner I am. The car had 39,990 miles on it. And like you said the highway miles are very, very easy/helpful in terms of helping the CVT stay in a easy operation condition. And... I still enjoy driving the car smile
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231528 10/05/19 09:06 PM
cos Offline
bbhero,
What year is your Nissan?
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: 283,500 miles CVT fluid 1st change [Re: cos] #5231533 10/05/19 09:10 PM
B
bbhero Offline OP
B
Originally Posted by cos
bbhero,
Ooh yeah a 2008.
Re: 283,500 miles CVT fluid 1st change [Re: CR94] #5231534 10/05/19 09:11 PM
B
bbhero Offline OP
B
A belt. It is the Xtronic CVT in my model with the 3.5 L VQ motor.
Re: 283,500 miles CVT fluid 1st change [Re: bbhero] #5231559 10/05/19 10:12 PM
J
JeffKeryk Offline
J
Not sure what you mean; it's all good I respect all opinions.
I appreciate your good words.
And killer job on the CVT transmission service.
2018 Lexus RX450h
2006 Acura TSX
Page 1 of 3 1 2 3
