Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
110 registered members (Astro14, 71Chevyguy, 2015_PSD, 53' Stude, 97tbird, 15 invisible), 2,794 guests, and 22 spiders.
Topics305,851
Posts5,281,430
Members71,525
Kia 2.0 GDI Oil consumption #5231233 10/05/19 03:59 PM
R
rmcnamara Offline OP
R
I have a 15 Soul 2.0 GDI with approximately 105000 miles. I have notice a pretty high oil consumption of about 2.5 qts in about 2k miles. I have been using super tech 5w-20 full synthetic. I did some research and spme people said to replace the PCV valve. we will see if that makes any difference. Can anyone point me to an oil with a low volatility. Preferably not in the ultra high end category like amsoil etc.
Thanks
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231249 10/05/19 04:19 PM
danez_yoda Offline
I highly doubt changing the oil will make a difference. Super tech went head to head with Redline on Project farms test of evaporation loss. It was a close fight that redline slowly edged out.
https://www.youtube.com/watch?v=zwqt5vI0o1A
Three main things.
1) Coked piston rings allowing oil to get burned.
2) PCV
3) valve guides leaking.
all of this assuming there was no oil leaking onto the ground.
Re: Kia 2.0 GDI Oil consumption [Re: danez_yoda] #5231253 10/05/19 04:22 PM
R
R
Forgot to add that underbody was dry. i changed pcv. how would I know of the other 2 main reasons?
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231273 10/05/19 04:43 PM
Danno Offline
I would go with 5W-30 PYB. No need for a synthetic with that much oil consumption. Going up a grade may lower the oil use.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231276 10/05/19 04:46 PM
M
Mad_Hatter Offline
M
Evaporation ain't your problem...
Bump it up to a 5/30 HiMi or maybe even a 10w30. The HiMi may or may not help with oil loose rings and valve seals but at +100k miles that train may have left the station. If you're not doing extended drains you might consider just using a dino since your cars got a drinking problem. An El Cheapo UOA would give some visibility into just how how "bad" things are inside... something to consider.
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231290 10/05/19 04:58 PM
csandste Offline
Why not do ST 5-30 Hi Mi? I have no burning of oil at all in my 17 with pushing 70K. Did this start suddenly?
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Kia 2.0 GDI Oil consumption [Re: csandste] #5231314 10/05/19 05:25 PM
R
R
I have done a few UOA's on this engine it didnt show any issues. I am very good with oil changes with an interval of about 5000. This issue has started recently. I am going to change the oil soon and really keep an eye on it.
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231339 10/05/19 05:45 PM
M
Mad_Hatter Offline
M
A problems never a problem until it's a problem.😉 So past UOA's are basically irrelevant at this point.
Sounds like you prolly know what to do already... good luck 👍
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231346 10/05/19 05:50 PM
demarpaint Offline
I'd bump up a grade in a HM oil. Or try a Kreen, Rislone, or MMO treatment with a higher viscosity HM oil.
God Bless Our Troops
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231351 10/05/19 05:55 PM
csandste Offline
Did you just change PCV. One thing at a time if you want to find out what's going on
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231356 10/05/19 06:06 PM
danez_yoda Offline
Finding out which is it is a job for a mechanic. They have diagnostic techniques. it might be a wet and dry compression test for the rings and a bor-o-scope check for the valve stems.
I would hit up the KIA forums to see if someone successfully stopped oil consumption after it started.
Many moons ago I use to heat about Maxlife doing that very well. Now with all the high mileage oils on the market, they might be worth a try as well. Give them 2-3 OCI to work though not just one. it takes a while to correct the problem.
I never recommend oil additives but Scotty Kilmer recommends AT-205 reseal
https://www.youtube.com/watch?v=ZngmqiVezAY&t=180s
Re: Kia 2.0 GDI Oil consumption [Re: demarpaint] #5231482 10/05/19 08:29 PM
J
jqgz Offline
J
Plus 1 for kreen and hiMi 5 w-30 supertech
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231729 10/06/19 07:40 AM
danez_yoda Offline
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5231859 10/06/19 10:08 AM
N
nascarnation Offline
N
The really important point is to keep it from running low and potentially damaging the internals.
So checking the oil level at each fuel fill would be good, like pretty much everybody did 50 years ago.
Re: Kia 2.0 GDI Oil consumption [Re: rmcnamara] #5232282 10/06/19 06:36 PM
R
R
I am going to be keeping a close eye on it. I had seafoam on hand so I added that and in a couple of days i will be changing the oil with some PYB hi mileage 5w30.
