Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Australia Energy Costs
by Y_K - 06/06/20 12:17 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
24 registered members (brslds, Bjornviken, b1amgm47, berlyn, ChrisD46, Boxnuts, 2 invisible), 723 guests, and 67 spiders.
Topics306,277
Posts5,289,436
Members71,616
75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD #5231225 10/05/19 03:52 PM
Spddm0n Offline OP
I can't believe how much has changed in just the last three years. I did a lot of this research on these oils three years ago as I began the process of rebuilding several Nissan Xterra/Frontiers that require a GL5 80W-90 Gear Oil for the Front/Rear Differentials. The rear all have LSD in them. At the time, I could just buy a quart bottle of Valvoline 75W-90 GL5 with LSD or 75W-90 without LSD, or so I thought. I just went through this whole mess with choosing a GL4 75W-90 that would work in my manual trans (no GL5 becuase of the synchros) - which was a total mess figuring that out (I chose the Redline MTL since it's the *thinnest and I'm having trouble with cold shifts in a Toyota MR2 and I need the same GL4 in the Xterra/Frontier - so I'm going to try the Redline MTL in the Nissan's also).
Anyway, am I right understanding that most modern synthetic gear oils all have the LSD in them? Is this safe for the non-LSD front axles in my Nissan Xterra/Frontier?
Also, I have some friends that complained the LSD additives in the synthetic gear oil are not enough...they needed to add more to stop chatter in the rear Diffs.
Could this be as simply as buying any 80W-90 GL-5 (like Sam's club) in a 5 gallon bucket and adding 4 oz of LSD additive to the rear axle only? That would help me save on fluids for 4 trucks.
I did do some research and many of the 80W-90 oils vary GREATLY on the kinematic viscosity indicies. How would one "guess" how the axles will behave, with such a wide variety of viscosities? Perhaps the Diffs are much less sensitive to viscosity than the manual trans/transaxles are??
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5231245 10/05/19 04:16 PM
T
tundraotto Offline
T
From all the research I have done for mine (was not looking for limited slip application) - all the ones that are - seem to say so specifically on the label in the back.
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5231300 10/05/19 05:08 PM
4WD Offline
I don't need LS version and buy Delvac 1 in gallon jugs … last I knew Summit had the best price but required $100 purchase for free shipping.
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5231343 10/05/19 05:48 PM
G
Gebo Offline
G
Tell me about it. Most of my autos call for 80w-90 (conventional) and I was shocked at the variability of the viscosities. I just gave up and went with 75w-90 synthetic. Maybe you can learn me something...
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5231347 10/05/19 05:51 PM
CT8 Offline
The oil is safe to use in a non limited slip and then you can add more Limited slip additive if needed. 75-90 syn is fine and it gets cold in Denver. The proper Redline viscosity MTL will be great.
2015 F150 2.7
2018 F350 6.2
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5231527 10/05/19 09:05 PM
Snagglefoot Offline
Here is an example of adding more LSA to diff fluid already containing LSA. In this case Valvoline. It’s in the fine print in the back. I’ve always heard you can put a diff fluid containing LSA into a non-LS diff, but why not seek out a cheaper non-LSA fluid.
If you want the job done right......do it yourself.
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5231661 10/06/19 05:46 AM
K
ka9mnx Offline
K
I don't know about all but Mobil1 and SuperTech Syn (confirmed by email to Warren Distribution) have LS additive. I've used Mobil1 75w-90 and ST Syn 75w-140 in my F150 with limited slip diff. Both worked as advertised without adding LS additive.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: ka9mnx] #5232850 10/07/19 11:32 AM
Spddm0n Offline OP
Thanks for all the replies!! Wow! So interesting learning about all of this! I finally landed on some old school Valvoline 80W-90. I used that in all my 80's and 90's Toyota trucks back in the day, though they didn't have limited slip. The Valvoline High Performance Gear Oil (conventional) suggests it has the LSD additives in it, so hopefully that will work. It's also one of the most viscous oils available in 80W-90 (at 40C). I'd probably prefer that, since I'd rather not get into rebuilding DIFFs and the fuel mileage hit at colder temps will only be for a few minutes. smile
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: 4WD] #5232855 10/07/19 11:35 AM
Spddm0n Offline OP
Nice. Yeah, I found the Valvoline product I'm thinking about getting for about $90 at Napa (business account price) for a 5 gallon bucket. Having said that, I've noticed a lot of the big box stores selling it for about $20/gallon. Not much more if I just want to get enough for one vehicle. Perhaps its all on sale because they want to get rid of the conventional stuff. smile
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Snagglefoot] #5232857 10/07/19 11:39 AM
Spddm0n Offline OP
Wow! Where in the heck do you get that?! They don't sell that in the US. I would love to get my hands on that! Is that a recent photo?
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: CT8] #5232872 10/07/19 11:49 AM
Spddm0n Offline OP
Nice. Ok, I'm going to try the Valvoline product with the additive, as is, and I'll look for some additive if I get some chatter in the rear.
Thanks for the thought on the Redline. The actual Redline MTL I bought for the transmission is a 75W-90 GL4, but I did just find the Redline 75W-90 GL5. Looks like that could work too! That actually looks like a great oil. Less viscous in the cold too. I got lucky buying my 5 gallons of the Redline MTL, but I wasn't so lucky finding a deal on the GL5 75W-90. That stuff is no joke!!! smile
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5232896 10/07/19 12:13 PM
Spddm0n Offline OP
*SPECIAL NOTE*
I just got off the phone with Valvoline and they said they NO LONGER HAVE LSD ADDITIVE in their 80W-90 High Performance Gear Oil (conventional)! They changed it about a year ago. Plus, they do not sell the Valvoline VP011 LSD additive retail. They only supply that to shops that have been "trained" to use the product. They also said they do have it in all the synthetic products, and in the concentration of 4 oz/quart of LSD additive. Wow! The VP011 additive by itself is suggested as 4 oz/1.8 quart...about 1/2 the concentration of the synthetic additive.
I guess the search continues!!!
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5233017 10/07/19 02:08 PM
4WD Offline
For me, it's fairly simple. If I have one that calls for LS FM … I get Mobil 1. If no FM, I get Delvac 1.
Think the reason Summit Racing carries the Delvac 1 is for the Porsche fans - they are not really a trucker store.
BTW: Have not seen an owners manual not call for synthetic in many years,
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Spddm0n] #5236336 10/10/19 08:37 PM
Snagglefoot Offline
Yes, this is a recent photo taken at a NAPA store in Calgary, Alberta, Canada. smile
Re: 75W-90 (OR 80w-90) GL5 DIFF FLUID WITH LSD [Re: Snagglefoot] #5236935 10/11/19 12:16 PM
Spddm0n Offline OP
Wow! Crazy! That's unfortunate the rules are different here and I can't buy it.
Oh well, I was less than satisfied with Valvoline's decision to modify the conventional oil by removing the LSD additives, and still represent the product with the same part number.
