Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
19 registered members (4WD, 330indy, blufeb95, Astro14, 340_Magnum, 3 invisible), 833 guests, and 38 spiders.
Topics306,079
Posts5,286,966
Members71,596
What were the issues with the FCA 3.0 EcoDiesel? #5230936 10/05/19 09:29 AM
T
Tikka Offline OP
T
Hi Lads
Hope this is correct section to post this.
I have read that the 3.0 EcoDiesel Engine as fitted to the Grand Cherokee and Ram pickup truck has suffered from failures.
Could anyone help as to what these failures were please?
I read that FCA changed the Oil spec to try alleviate the problems. I have read of a few cases now of big end bearing failure here in UK.
Any help would be appreciated as I am considering replacing my 2008 Grand Cherokee with the newer WK2.
Many thanks.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5230963 10/05/19 09:53 AM
B
billt460 Offline
B
The biggest problem I heard of with them, (this was back in 2015 when I was considering one in my Grand Cherokee), was the timing sprocket on the camshaft was pressed on, and not welded. This caused issues with many engines, when the sprocket got loose and started to slip. I don't know if they corrected it or not. I know they stopped offering the Ram pickup with the Eco Diesel for a brief time. I think there were several other issues with that engine as well.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5230968 10/05/19 10:06 AM
M
maxdustington Offline
M
Timing sprocket and I believe the stop/start caused rod or crank wear that made them change their oil spec.
I see A LOT of them on the roads in Toronto. I would say 20-25% of newer Rams that I see have that mill. Good highway MPG for a truck.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5231019 10/05/19 11:03 AM
M
MParr Offline
M
There were also turbocharger problems.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: billt460] #5231584 10/05/19 11:27 PM
CleverUserName Offline
I was also considering buying a 2017 Ram Ecodiesel as they were basically giving them away, however I changed my mind because I didn’t want a turd and bought a GMC Canyon Duramax instead.
The timing sprocket isn’t a real issue. There is a YT video of a guy rambling on about it but it’s rare and not one of the common failures with this engine.
The main cause of engine failures with the 3.0 ecodiesel has been big end and rod bearing failures. FCA changed the oil spec to CJ-4 and also reprogrammed the TCM to limit lugging which helped but also reduced the advertised FE by 3-4 MPGs. Another cause of oil related failures is the cheap oil cooler which is prone to leaking which also contaminated the oil causing engine damage.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5231587 10/05/19 11:37 PM
A
AVB Offline
A
Not just bearing problems but breaking crankshafts. They claim the engine has enough power that it's snapping crankshafts in certain situations. Lately we have been starting to see holes in the intake manifold.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: AVB] #5231598 10/06/19 12:32 AM
bdcardinal Offline
The 2011-2012 Super Dutys with the 6.7L diesel would snap crankshafts. I have personally seen 3. Our tech still has the front part of one with the snout and a counterweight. Crazy part was they all still ran perfectly fine and made power, just sounded like death. The breaks are all clean breaks but did it in such a way that the crank would still spin with the broken parts meshed.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: bdcardinal] #5231641 10/06/19 03:06 AM
Skippy722 Offline
I gotta ask... how are they snapping crank shafts? That should be the single strongest thing in an engine!
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5231941 10/06/19 11:40 AM
A
AVB Offline
A
I don't think any cranks have broken in Jeeps only the trucks. Last I heard it was from towing and spinning tires. I would have thought that the automatic transmission would slip before the crank broke.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Skippy722] #5232060 10/06/19 01:55 PM
bdcardinal Offline
It was a metallurgy issue. Only affected the 2011 and 2012 trucks. The first picture shows the rest of the crank still in the block with the front section taken out.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: CleverUserName] #5232231 10/06/19 05:25 PM
T
Tikka Offline OP
T
Hi
This is the kind of thing I am hearing about in UK. What do you mean by 'lugging'?
Is the big end bearing failure down to fuel dilution? Is this why they thought a HDEO could cope better?
Does the oil cooler issue lead to coolant entering the oil?
Thanks for your help.
Tikka.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5232233 10/06/19 05:27 PM
T
Tikka Offline OP
T
Hi Lads
Thanks to everyone for helping. It is appreciated thumbsup
Tikka.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5232244 10/06/19 05:47 PM
M
mk378 Offline
M
Lugging is running an engine at unusually low rpm (high gear relative to the road speed) with the throttle wide open or nearly so. Though a diesel is sort of intended to run this way and handle it better than a gas engine, it is a lot of stress on the bearings.
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5232314 10/06/19 07:06 PM
BeerCan Offline
Lugging is like when you shift from 1st to 3rd or 4th by mistake. If the car does not stall and you floor it you go nowhere fast and the engine is crying.
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: What were the issues with the FCA 3.0 EcoDiesel? [Re: Tikka] #5233200 10/07/19 05:37 PM
T
Tikka Offline OP
T
Hi
So that is what 'Lugging' means. We call it 'labouring' over here.
Not easy to do with an auto box though smile
