My little 02 sc2 uses about a quart of oil in a 1,000 miles. Typical Saturn stuff.
I am going to do an engine flush procedure and piston soak most likely. What would be the best chemical to use for this job? Something that will soften the carbon on the piston rings. What would you use? Engine has 122,000 on it runs great compression is perfect it just has stuck oil control rings. .
