Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
104 registered members (3Aone, 1978elcamino, 2015_PSD, 69GTX, 2002 Maxima SE, 9 invisible), 2,634 guests, and 39 spiders.
Topics300,349
Posts5,173,864
Members70,487
Most Online3,825
Jan 19th, 2020
2019 Regal TourX GKN Twinster fluid change. #5230156 10/04/19 11:13 AM
L
LotI Offline OP
L
Based on Molakule and Jim Allens' advise in past threads I changed the rear diff fluid early in my new Buick TourX. It uses the GKN Twinster differential with has the ability to send 100% of torque to either axle with computer-controlled clutch packs. The Focus RS uses the same diff and 75w-85 and friction modifier.
It still uses Dexron LS in the diff and CHF-11S in the actuator system. The car just turned 6000 miles and based on some issues some are reporting on forums I tackled it myself. There is no service interval on either fluid, and no drain for the CHF11. Capacity is listed at .92qts and fill until it drains out of the fill hole.
It was extremely easy needing only one tool, a 10mm hex wrench. The rear sway bar is close to the fill plug so I had to break out the trusty Craftsman ball-end hex wrench and it just fit. The fluid didn't look bad for 7k miles but the drain plug magnet was pretty maxed out. I refilled with Castrol 75w-90LS from a past AZ clearance(good to have a stash) and will report back if it doesn't get along with the clutches.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5230166 10/04/19 11:25 AM
cwilliamsws6 Offline
After reading this I decided to do some research on the Twinster. Very neat how it all works! Also surprised how easy it was to get to, considering how most newer cars tend to be.
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5230216 10/04/19 12:32 PM
L
Leo99 Offline
L
Is that a normal amount of debris on the drain plug for a newish car?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: Leo99] #5230220 10/04/19 12:41 PM
4WD Offline
I have always been an early drive line oil changer and it's been common for me to see magnets loaded - and sometimes to actually see metallic particles in the oil.
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: 4WD] #5230227 10/04/19 12:50 PM
SLO_Town Offline
I agree with 4WD. I have always changed drive train oils on my new cars within 1K miles, and then again at 5K. Diffs were one thing, but I always found it SHOCKING how much metal debris came out of a manual transmission on the first drain!
Scott
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5312446 01/03/20 05:27 PM
J
Jmlo96 Offline
J
How is the fluid holding up for you?
I'm having a heck of a time figuring out what all this differential actually requires. My TourX just turned 17k miles and your post confirms my feeling that the rear differential fluid needs to be changed now. I was shocked to learn this car has the same rear differential as a Focus RS.
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5312679 01/03/20 09:53 PM
L
LotI Offline OP
L
Just passed 14k in mine, seems just fine.
I would change it, like any rear diff within 10k miles, then regular changes. I’m probably going 30k miles between changes since it only needs a quart and is really easy to change.
GM says Dexron LS is the correct fluid. 88862624 if you want it from your dealer. It’s a 75w-90 made my Mobil with LS additive in it.
[Linked Image]
[Linked Image]
11 Kawasaki KLR 650
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5313514 01/04/20 09:47 PM
J
Jmlo96 Offline
J
Thanks for getting me this info. I ended up changing mine this morning. I used Redline 75w85 hypenoid fluid. I already had some from my Toyota.
I actually noticed that the driveline seemed smoother from changing the fluid.
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: Jmlo96] #5313794 01/05/20 10:09 AM
L
LotI Offline OP
L
How fuzzy was your magnet?
11 Kawasaki KLR 650
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5313874 01/05/20 12:11 PM
J
JTK Online Content
Online Content
J
Looks cool! Good write-up.
Lotl, is there a PTU, T-case of some sort of center diff oil you can change on your TourX?
Reason I ask is, I was disturbed at how horrible the T-case oil looked on my 2019 Nissan Pathfinder at like 25k miles. This little T-case only holds a few ounces of gear oil and has exhaust plumbing near it. The rear diff oil on the other hand looked relatively new yet. No drain plug magnets on either.
What i'm getting at is the manufacturers typically list no service interval for these boxes and given the amount of AWD / 4x4's out there these days? As time goes on, you gotta know so many will go to the bone yard because of failed drive system components that cost thousands to replace.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: JTK] #5313973 01/05/20 03:22 PM
L
LotI Offline OP
L
There is a PTU located behind the transmission that splits the power. It only holds 0.69qts of gear oil but I haven’t been able to track down d&f instructions. There may not be a drain.
GM p/n 19351882 for those in the US. I haven’t talked to my dealer but online it’s over $50/qt. It looks to be a 75w-90 GL5 EP lube that’s been used in AWD GM vehicles from Germany(Opel) like the Regal.
ACDelco:
“ ACDelco GL-5 75W-90 Synthetic Power Transfer Unit (PTU) Lubricant helps improve fuel efficiency, reduce operating temperature, and improve thermal stability. GL 5 gear oil possesses high extra pressure (EP) effect. It is used in hypoid and other highly loaded gears. This gear oil is a heavy-duty, extreme-temperature-pressure GL-5 axle lubricant. It is designed to withstand the high temperatures encountered during extended high-speed operation and heavy towing while also retaining excellent fluidity at cold temperatures. The fully synthetic formulation offers oxidation and thermal stability. The formula contains superior oxidation resistance and longer seal life. This gear oil also keeps the power transfer unit lubricated to help allow efficient power transfer to differentials. ACDelco GL-5 75W-90 Synthetic Power Transfer Unit (PTU) Lubricant has been formulated to meet your expectations for durability and longevity.”
[Linked Image]
11 Kawasaki KLR 650
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5314014 01/05/20 04:07 PM
dareo Offline
Interesting. I'l have do do this on our TourX one of these (warmer) days.
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5314056 01/05/20 05:11 PM
L
LotI Offline OP
L
Doing a little research shows the 2020 Equinox/Terrain AWD use the same PTU fluid. Makes sense since the engine is the same 2.0T LTG
11 Kawasaki KLR 650
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5317963 01/09/20 05:37 PM
L
LotI Offline OP
L
Did an oil change today and got a close look at the PTU(literally as I was on my back).
There is a drain plug and a fill plug that have a 3/8” square drive head...nice. It means I can DIY. I’m contemplating using my M1 or Castrol 75w-90 but am worried about any proprietary additives that may be in the $50/qt ACDelco fluid.
I will probably break down and buy the fluid considering a failure would be much more than $50. I still have a UOA kit from Wix so I think that will be used for it.
11 Kawasaki KLR 650
Re: 2019 Regal TourX GKN Twinster fluid change. [Re: LotI] #5318187 01/09/20 08:50 PM
J
Jmlo96 Offline
J
About the same as yours. Here is the old fluid and the remains of the magnet. [Linked Image]
[Linked Image]
