Originally Posted by bubbatime
If you google larger battery upgrade CRV, you can find a tutorial. Its super easy. The battery tray cost about $10 straight from Honda, then you can use the V6 battery which is much larger, about 50% larger and should last longer with more amperage. Plus the bigger battery might be cheaper, as the 51R size Honda batteries are usually over $100 easy. You can use a group 24 battery, which you can get for $49 at Walmart.
This ^^^^^^^^^^^^^
Exactly the thing to do.... And the 24f Valuepower battery from Walmart is a East Penn 624fmf battery... A really good deal. That battery weighs 41 pounds and has a 3 year free replacement warranty at Federated Auto and is a 2 year free replacement warranty from O Reilly's... And for $48.88...
