Michelin Defender on Civic
by jharrison - 12/06/19 08:14 PM
2012 GMC Terrain 3.0L V6 Valve Cover Replacement
by benjamming - 12/06/19 07:30 PM
Cam2 CVT fluid is green, and so is Transtar
by slacktide_bitog - 12/06/19 06:59 PM
Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
Stahle, BajaBu, Bayoubrad, Fog42, glassmaker
70053 Registered Users
99 registered members (andyd, 4WD, Astro14, 2004tdigls, AC1DD, 11 invisible), 2,043 guests, and 62 spiders.
Topics298,385
Posts5,134,253
Members70,053
Most Online3,589
Nov 2nd, 2019
Air Compressor Oil #5229984 10/04/19 06:27 AM
B
BigJohn Offline OP
B
I just purchased a McGraw air compressor from Harbor Freight a couple days ago. I poured in the oil that was provided, which was nearly .... crystal clear. After only about 10 fill cycles, the oil is already a mid-gray color looking at it through the sight glass. I want to get those break-in metals out and I want to avoid the sump starting to sludge at all.
I assume I should probably run the compressor until the sump and oil are pretty hot and then pull the drain plug.
I wonder if I should fill the sump with some 20wt motor oil... heat it up again and dump it immediately.... just as another flush.
Then I am wondering what to pour in for longer term????
The compressor is in my garage and is only used occasionally.... maybe 2-3 times a month in the winters. In the summer it is used much more. It also gets cold here in the winter, easily down to the negative 10's in January and February, with the garage dropping close to freeing.
I don't mind paying a premium for great synthetic and I can easily get Royal Purple Synfilm 100. (I will not use motor oil, as I don't want the risk of additive build-up.) There seem to be other, great oil choices, but they are sold in only gallon or 5 gallon jugs/pales.
This 20wt is also available from Amsoil. Link CLICK
Any other opinions and/or suggestions?
14 Ram 1500 EcoDiesel 4x4, T6 5w40
15 Mercedes ML250 BlueTec, PenEuro 5w30
17 Kawasaki V-X 300, T4/T6 Blend
16 Honda VFR1200x, T4/T6 Blend
05 KTM 950 ADV-S, T4/T6 Blend
10 Mahindra 2816 HST, T6 15w40
Re: Air Compressor Oil [Re: BigJohn] #5229992 10/04/19 06:39 AM
Chris142 Online Content
Online Content
Amsoil makes a compressor oil.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Air Compressor Oil [Re: BigJohn] #5229998 10/04/19 06:43 AM
dlundblad Offline
Depends on what your manual says, but I am assuming they'd prefer a 30 Weight non detergent oil rather than a 20.
Get the oil stirred up and do a drain and fill with your choice of oil. If you're worried, maybe fill it with a cheap 30 weight ND and use that as the final rinse before adding the good stuff.
Ingersoll Rand has an "all season" oil that's around $9 a quart at Tractor Supply IIRC. Judging by the name, I am assuming it's synthetic.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Air Compressor Oil [Re: BigJohn] #5230075 10/04/19 08:51 AM
B
billt460 Offline
B
Originally Posted by BigJohn
It also gets cold here in the winter, easily down to the negative 10's in January and February, with the garage dropping close to freeing.......
Operating it in freezing conditions can cause problems. When I purchased mine, I was living back in Illinois. In the Winter the provided oil got too thick, and would trip the breaker. I drained it and put in Mobil 1, 0W-30, and after that it would start up and run effortlessly on the coldest of days.
Re: Air Compressor Oil [Re: BigJohn] #5230282 10/04/19 01:46 PM
L
Linctex Offline
L
I always add a little oil with a "tackifier" in it... like chainsaw bar chain oil.
If you don't use the compressor for a long time, the tackifier will keep internal stuff oily - and fight moisture (always a problem)
Re: Air Compressor Oil [Re: BigJohn] #5230351 10/04/19 02:57 PM
dave123 Offline
Synfilm 100 is excellent run it in my 7.5 hp at temps above 15F below that little iffy.
Re: Air Compressor Oil [Re: BigJohn] #5230364 10/04/19 03:08 PM
sloinker Offline
My Quincy specs Quincy oil and filters for its extended warranty. The compressors at work use synthetic oils of differing pedigrees depending on type of compressor. Some of the big multi-stage types use an ester based synthetic.
'16 Tiguan TSI Ravenol VST 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Air Compressor Oil [Re: BigJohn] #5230372 10/04/19 03:23 PM
Duffyjr Offline
Aren't you suppose to start them with the valve cock open when it's cold until the motor warms up a bit?
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler VWB SAE 30
Re: Air Compressor Oil [Re: BigJohn] #5230385 10/04/19 03:38 PM
R
Rat407 Offline
R
I run AMSOIL's compressor oil in my Kobalt 80 gallon compressor. Oil has been in it for 6yrs and still looks good through the site glass. To me for the cost, why cheap out. Throw a quality synthetic in and it can only pay it forward down the road as to putting in mineral oil. Not like you change it out very often.
2002 Silverado 5.3 0w-20 AMSOIL
Re: Air Compressor Oil [Re: Chris142] #5230386 10/04/19 03:40 PM
L
LotI Offline
L
Yup, I've been running their ISO100 in my compressor for years after the initial fill. Seems fine and although pricey, you don't need much in a typical compressor. It's available pretty much anywhere Amsoil is sold. I picked mine up from Weaver off the shelf.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: Air Compressor Oil [Re: BigJohn] #5230461 10/04/19 05:19 PM
B
BigJohn Offline OP
B
Ran to Big R and they had this for sale for $3.99 each. I purchased two.....
Heated the compressor up.... dumped the factory oil. Filled with Mag1...... heated up again and dumped..... and filled with Mag 1. Each fill took about 7 oz... so I only used one of the little 16oz bottles.
Oil was filthy dirty on the first dump and only slightly dirty on the second dump.
[Linked Image from i.imgur.com]
Re: Air Compressor Oil [Re: Duffyjr] #5230579 10/04/19 07:43 PM
clinebarger Offline
Compressors have Unloaders, Cheaper ones unload via a schrader in the pressure switch, Commercial/Industrial units have a Centrifugal Unloader.
The short burst of air escaping when the unit shuts down at the pressure cutoff IS the Unloader doing it's job.
Continuous run compressors are different.
2001 Chevy Camaro L92/4L80E
Re: Air Compressor Oil [Re: clinebarger] #5230788 10/05/19 03:44 AM
Duffyjr Offline
Thanks, I always wonder why it sounds like it is releasing a little air when it shuts off but I was referring more to starting one up that had been sitting when it's really cold like single digits. I have a Makita Mac700 and when I bought it a fiend of mine that worked as a building type maintenance guy said to open the valve so it's not trying to build pressure right away when it's really cold until it runs a bit.
Re: Air Compressor Oil [Re: LotI] #5230825 10/05/19 05:23 AM
2015_PSD Offline
Another vote for Amsoil compressor oil.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge 0W-20 + FRAM Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: Air Compressor Oil [Re: BigJohn] #5231743 10/06/19 07:05 AM
dlundblad Offline
[Linked Image]
Here’s the chart from the manual to my compressor. No idea where IR’s oil falls.
The manual specifically says not to run the compressor below 20*F too, which won’t happen on a normal basis, but will surely happen as it’s going to be used as needed. That said, it looks like I would need a winter and summer fill.
