I was doing research on GM E.O.S. and I found out, on a Cadillac owners website, that E.O.S. is supposed to contain 12 times the ZDDP of conventional engine oil. Also, E.O.S. uses what was called on the website, "standard 40 weight engine oil" fortified with ZDDP (and other stuff).
I bought some and the Chevy dealer told me that the name change and recommendation "not to use it as an oil additive", is because supposedly prolonged use of E.O.S. may cause catalytic converter problems and in turn, effect a car's pollution-making. I have read differing opinions on whether it hurts a converter.
I also came across some information about E.O.S. regarding engine storage. Zinc is supposed to be a good rust preventer.
I'd like to know whether E.O.S., with its large amounts of zinc, is good to add to an engine of a vehicle, that is in storage (to prevent internal rust). The information I found, so far, was that this is true.
Maybe someone at BITOG has some information or comments about this storage idea.
I'd like to know more.
Thanks in advance!
