1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
63 registered members (ArrestMeRedZ, alarmguy, amblerman, 86cutlass307, aquariuscsm, aray, 7 invisible), 1,287 guests, and 48 spiders.
Topics306,081
Posts5,287,022
Members71,596
Most efficient oil filter for Valvoline Premium Blue Restore Treatment #5228520 10/02/19 03:11 PM
The Critic Offline OP
I will be running Valvoline Premium Blue Restore for one oil change interval in the vehicles listed in my signature.
What is the most efficient oil filter available for my applications? Price is not a concern. The service interval will not exceed 10K miles.
Thanks.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228524 10/02/19 03:12 PM
SubieRubyRoo Offline
It comes in an gold can with that black grippy rubber-like stuff on the dome end.
De omnibus dubitandum.
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228539 10/02/19 03:23 PM
L
LeakySeals Offline
L
I'm not sure about running a high efficiency filter during a cleanup. Will clog fast possibly impacting flow. Maybe the oil change right after would be a better idea.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228543 10/02/19 03:25 PM
L
LeakySeals Offline
L
Where do you get that? i would like to try.
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228544 10/02/19 03:26 PM
Leaky, if that was the case, why would Cummins have a specially made combo bypass filter as their only recommended filter when using this oil on the ISX engine it's intended for? Once you break all that soot/varnish/agglomerates free, you don't want them recirculating through the oil passages where they can wreak more havoc than their original locations...
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: SubieRubyRoo] #5228552 10/02/19 03:34 PM
L
LeakySeals Offline
L
No idea about that. I was commenting on the Honda and the Prius in Critics sig. I think an avg filter will perform just fine. Will catch anything large enough to cause a problem, become more efficient as it loads up. Without impacting the flow, which IMO is more important than efficiency.
Edit: A quick google seems to confirm my opinion. See the third bullet point. While they boast about the efficiency of the recommended oil filter, they also recommend this filter to prevent premature oil filter plugging. So they are concerned about it. Transfer this to an auto, maybe a regular filter is a better choice.
https://www.ryderfleetproducts.com/valvoline-877377/premium-blue-restore-10w30-gallon-p-vvl-877377
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228570 10/02/19 03:46 PM
diyjake Offline
Depending on how long you plan to run the OCI, I would go with Fram Ultra and change it half way.
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: LeakySeals] #5228605 10/02/19 04:11 PM
Sounds like a Fram Ultra.
Yep. Any cummins dealer should have it in stock.
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228667 10/02/19 05:32 PM
Rat407 Offline
AMSOIL Ea15k01 for the Prius
AMSOIL Ea15k13 for the Honda
These are what I would run.
2002 Silverado 5.3 5w-20 AMSOIL
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228708 10/02/19 06:22 PM
P
PandaBear Offline
P
Personally I would change oil filters every 2-3k during that 10k OCI. If a lot of things get cleaned you do not want a super fine filter, you want surface area, and frequent change to make available that surface area.
Someone said oversize Fram Ultra.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228730 10/02/19 06:51 PM
M
mattwithcats Offline
M
2011 Prius
Wix 57064XP
Or
Fram XG10358
Look at Rock Auto...
Bottom of page...
https://www.rockauto.com/en/catalog/toyota,2011,prius,1.8l+l4+electric/gas,1447548,engine,oil+filter,5340
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228735 10/02/19 06:53 PM
M
M
2007 Honda Accord
Wix 57356 or Wix 57356XP
2009 Smart Pure
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: SubieRubyRoo] #5228743 10/02/19 06:55 PM
53' Stude Offline
What is it again? LOL
2009 Toyota Camry LE
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: 53' Stude] #5228751 10/02/19 07:05 PM
It's really close to the 1960's Hurst Gold, almost metalflake, and has some stuff on the dome end resembling aircraft carrier flight deck surfacing, but in black. Simple! LOL
Re: Most efficient oil filter for Valvoline Premium Blue Restore Treatment [Re: The Critic] #5228760 10/02/19 07:11 PM
PimTac Offline
I would use a Valvoline filter. 😉
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
