I would check dipstick @ 1000 miles. Only way to know. No sense fretting about a problem you may not have.
Might consider a good traditional break-in process. Consider using Tow/Haul mode on the shift selector often. It steps up through each gear of the 10-speed without skip shifting and equally, or even more important, it will step down through each gear on decel for engine braking. That nets you some vacuum pulls on the piston rings to balance the pressure/acceleration runs as you do the brisk throttle acceleration runs to help seat the rings. Sport mode does the same with gears but holds gears longer than tow/haul and in combination with the more aggressive throttle map of sport mode, it can put you closer to redline rpm than is recommended for break-in if you're not careful. As usual, don't exceed 75% of tachometer redline until at least 1000 miles are accumulated.
