Originally Posted by 69GTX
I want more viscosity protection at cold startup as long as the ambient temp allows the oil to flow....which in my region in dead of winter is a 10w. For anything above -10F......the 5w will easily flow. And above 0F the 10w will easily flow. A friend of mine in SoCal runs a 15w-30 concoction on his vehicles year round. It all flows. So it's all good. 0w will give you less protection at startup.
But you aren't getting "more viscosity protection" with the already massively thick oils at cold temperatures. 0W rated oil will not give you less protection at startup, plain and simple. That's not how it works.
0W rated oils will give somewhat easier starting at very low temperatures, as well as guaranteed flow to the pickup tube at those same extremely low temperatures. It will also perhaps give better fuel economy. But there is nothing there about protection, neither better nor worse. "Protection" comes at the other end of the grade designation, not from the winter rating.
