1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
74 registered members (ArrestMeRedZ, ARB1977, amblerman, 4WD, 94astro, 40w8, 4 invisible), 1,412 guests, and 75 spiders.
Topics306,081
Posts5,287,038
Members71,596
Page 1 of 5 1 2 5
Any reasons NOT to use Rotella 5w-40 in Euro Turbo? #5227924 10/01/19 08:03 PM
Z
Zolton Offline OP
Z
Other than mfg specs, seriously.
I looked at a bunch of new oils, and am not impressed.
Psychical specifications, UOAs, VOAs, chemistry etc what is RTS missing that other high HT/HS mfg spec oils deliver?
[Linked Image from i.imgur.com]
Pretend you already had plenty of Rotella in abundance. What and why would you seek out a different oil for VW 1.8T. It's not the only car in the family, so I don't want to get too fussy.
Twice a year changes.
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5227929 10/01/19 08:19 PM
Z
Zolton Offline OP
Z
VW 502 is such a weak baseline for a spec anyway.
I'd be doing myself a favor, right?
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5227957 10/01/19 09:14 PM
J
Jimmy_Russells Offline
J
Phosphorous and zinc content. 5w30 MV is probably a better choice, IMO.
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Jimmy_Russells] #5227963 10/01/19 09:20 PM
Z
Zolton Offline OP
Z
I thought zink was a good additive to have in excess.
Is this for catalytic converter life?
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5227966 10/01/19 09:24 PM
Z
Zolton Offline OP
Z
A lot of car sites, people claim they get their best UOA results on Rotella. BMW, Subaru....etc
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5227967 10/01/19 09:26 PM
DrDanger Offline
With 2 changes per year, 6k miles max, no issue.
It is a thickie though, might rob you of some mpg /half a horse.
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5227973 10/01/19 09:40 PM
Z
Zolton Offline OP
Z
Quote
"Hello.
I am driving a 2002 VW Passat 1.8T with 91,000 miles on it. I have read good
things about your previous generation 5w40 Rotella T in VW's 1.8T, even though it is primarily a diesel oil.
Is the new T6 5w40 a good match for this engine? I have not any
sludge issues, but the previous Rotella T had a good reputation for keeping
engines clean. I do not see any reference to use of this new product (on the package) in gasoline engines, where the previous Rotella T did state it was safe for gasoline engines.
Steve"
The following day, this is the reply I received from Shell:
"Hello Steve,
Your engine may use Rotella T or T6 since VW allows API SJ or SL
rated oils. Rotella has not be qualified against the VW
specifications but meets API SM and prior S ratings for gasoline
engines. I think you will have good service with... Rotella T6 Full Synthetic 5W-40.
For your engine:
"Engine oil specifications for 4 and 6 cylinder engines
The following terms must appear on the oil container singly or in
combination with other designations.
Multi-viscosity energy conserving oils such as: VW 500 00, VW 502 00
Multi-viscosity oil: VW 501 01
Multi-viscosity oil according to: API-SJ or API-SL, SAE 5w-40 or SAE
10w-40"
Regards,
Keith
Shell Technical Information
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5227977 10/01/19 09:49 PM
Z
Zolton Offline OP
Z
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5228061 10/02/19 03:35 AM
J
J
Are you just looking for someone to tell you it’s fine to use?
Yes it is about emissions equipment. A great deal of people that use it in the tuning world have either deleted cats so they don’t care, or only keep the thing for 3-4 years and they never make it to the point where it starts to become a problem.
Since this car has already made it fifteen years with whatever oil I would imagine this would also be fine, although probably extreme overkill in viscosity.
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5228071 10/02/19 04:30 AM
L
Lowflyer Offline
L
@Jimmy_Russells
MB 228.31, Volvo VDS-4.5 or MAN M3575, thats for vehicles without cats?
There are Catepillar machines, with SCR cats laugh
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5228107 10/02/19 06:03 AM
demarpaint Offline
You have to lay the other specs the oil meets on top of the VW spec. that typically fills that graph up quite a bit. Anytime I used that graph the oil I looked at met more than one spec. Usually a VW Spec, Porsche Spec, MB, GM Dexos2 spec, etc.
God Bless Our Troops
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5228123 10/02/19 06:29 AM
K
krismoriah72 Online Content
Online Content
K
From Delo XSP 5w40 PDS..
"Delo 400 XSP SAE 5W-40 with ISOSYN Advanced Technology is a mixed-fleet motor oil recommended for naturally aspirated and turbocharged four-stroke diesel engines and four-stroke gasoline engines in which the API CK-4, API SN or API SN PLUS service categories and SAE 5W-40 viscosity grade is recommended. It is formulated for engines operating under severe service and a wide range of climatic conditions.Delo 400 XSP SAE 5W-40 with ISOSYN Advanced Technology is excellent for use in engines developed to meet 2010 emissions standards and in engines equipped with features like four-valve heads, supercharging, turbocharging, direct injection, shorter piston crowns, higher power density, intercooling, full electronic management of fuel and emissions systems"
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: krismoriah72] #5228137 10/02/19 06:58 AM
demarpaint Offline
That is another good oil. It is the current fill in my 88 E-150.
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Lowflyer] #5228184 10/02/19 08:27 AM
J
J
Originally Posted by Lowflyer
@Jimmy_Russells
SCR does not work the same way. Gasoline does not use DEF (or similar).
Re: Any reasons NOT to use Rotella 5w-40 in Euro Turbo? [Re: Zolton] #5228307 10/02/19 10:52 AM
Z
Zolton Offline OP
Z
Let's just say I don't care about cats. I'm more of a dog person anyway.
Page 1 of 5 1 2 5
